Jan 16, 2010 10:56:53 GMT
i need to replace a bit of fuel hose on the golf , its rubber hose onto a fairly stiff but not un kinkable plastic hose ive done them before and its a struggle..i dunk the rubber hose in boiling water first to help it any ideas on a lube i could use? something that wont make it want to slide off after its on ?
Gray
Silence isnt golden!!!
Jan 16, 2010 11:18:50 GMT
A bit of washing up liquid would do wonders, also while the hose is in the boiling water use a pair of needle nose pliers inside it to keep a steady pressure on it and gently stretch it as it heats up
Jan 16, 2010 11:26:03 GMT
wont the soap make it a bad fit once its on tho?
Gray
Jan 16, 2010 11:30:40 GMT
If its tight it should be fine plus WU liquid should dry up and dissapear Have you tried spit yet? sounds wierd but it does work
Jan 16, 2010 11:36:37 GMT
Yeah,spit makes a good lube.....for all sorts of things ;D
Gray
Jan 16, 2010 11:38:07 GMT
Yeah,spit makes a good lube.....for all sorts of things ;D LMAO ;D
Jan 16, 2010 11:39:26 GMT
Yeah,spit makes a good lube.....for all sorts of things ;D yeah lol i was telling a mate i felt like some porno dude gobbing on stuff lol got 8mm on there and it was tight but leaks ...ive ordered some 7mm which i found its sposed to be , so I'm thinking its gona be a fight , and its near the exh mani for added danger if it leaks
Jan 16, 2010 13:38:34 GMT
if ure afriad of it slipping off if u lube it try putting a jubilee clip on when its on to tighten it up
2001 Micra 998 - Daily
1986 Mini Mayfair 998 - Former Daily - Garaged
Jan 16, 2010 14:06:49 GMT
yeah, fuel clips are handy.
Jan 16, 2010 14:14:17 GMT
no need for the fuel clamp chat , i hadnt planned having 5 bar fuel hose with no clamps
will
Jan 16, 2010 14:38:04 GMT
Hairspray, helps it slide on a dries sticky too, used it for bike grips many times.
djefk
Jan 16, 2010 15:18:22 GMT
The best thing to use is silicone spray...
Hitch
Jan 16, 2010 16:40:02 GMT
Hairspray, helps it slide on a dries sticky too, used it for bike grips many times. Beat me to it, was gonna say exactly the same thing.
