Miller
Jan 18, 2010 20:37:56 GMT
I'm after a set of Ronal Turbos for my Mk2 Golf below. I think these look really nice and is the wheel tyre combo I'm after... not a radical choice but in my opinion one that definitely works I'm just wondering if anyone has brought them new and can recommend me a wheel shop on-line to try, as my usual wheel suppliers can't get them. Ive seen them cataloged on various websites but would rather deal with one that others have had good experiences with. Also if anyone wishes to share pictures of ronals on their cars then I'd love to see them. Many thanks, miller
Sammo
Club RR Member Number: 103
Ronal R10 TurbosSammo
@sammo
Club Retro Rides Member 103
Jan 18, 2010 20:50:33 GMT
My old G40 ;D
Jan 18, 2010 20:59:44 GMT
There's usually loads on ebay.
Miller
Jan 18, 2010 21:12:48 GMT
quackshot
...friggin' cars...
Jan 18, 2010 21:17:18 GMT
I've got some on nearly new 195/45/15s one rim has a tiny little dink in the lip (the rear wheel in the pic), could be pushed back in easily but I've never bothered as holds air fine and still perfectly balanced. Front tires are Toyos, rears are something similar, all with 5mm+ directional tread with even wear. Last time they were fitted to a car (my old mx5) Would like to see £450 OVNO (I would say the wheels are 9/10 condition)
Last Edit: Jan 18, 2010 21:18:07 GMT by quackshot
Miller
Jan 18, 2010 21:35:38 GMT
are MX5s the same pcd as Golfs? If so I could be interested.
RobinJI
Jan 18, 2010 21:40:21 GMT
Yep, they're 4x100 I believe.
I've got some on nearly new 195/45/15s one rim has a tiny little dink in the lip (the rear wheel in the pic), could be pushed back in easily but I've never bothered as holds air fine and still perfectly balanced. Front tires are Toyos, rears are something similar, all with 5mm+ directional tread with even wear. Last time they were fitted to a car (my old mx5) Would like to see £450 OVNO (I would say the wheels are 9/10 condition) did a deal happen here or are these ronals still available?cheers
1980 Scirocco storm, 1980 Scirocco Gli
1982 Fiesta XR2, 1991 clio 1.8 16v
1982 Golf GTi , 1989 Astra GTE 16v
1985 RS Turbo , 1989 Golf GTi 16v
1986 RS Turbo, 1988 RS Turbo
dugong
One Of Us Will Live To Rue The Day We Met Each Other (Wire : 2008)
MX5s and Mk 2 Golfs are indeed the same PCD.
If it's just the shape you're after, and they don't *have* to be Ronal Turbos, it's worth noting that the Compomotive TH 2 wheels is very similar and often used in rallying. If you sprayed a set of those up or had them mirror finished, it may work out cheaper for you.
I'm not sure if the TH 2 was made in 4 x 100 though.
Best getting a barely used set second hand, they're a common wheel so you shouldn't have much problem finding a set for a decent price.
as said.. ebay.. they're bloody pricey off the shelf !
if it has pistons or tits; its going to be expensive
nizzer
