CIH
Jan 27, 2010 18:53:57 GMT
Hi any ideas what I can use to replace knackered sound deadening on the cheap ? My daily bluey had been letting in water, but seems now ok, so the interior is going back in. Needs to be cheap as I'm seriously bored of the thing so it's either getting fragged or sold in the next couple of months.
Granted the most likely buyer will be pulling the interior out and fitting a scaffold roll-cage and dulux paintjob but I may as well stuff the interior in while I use it.
Jan 27, 2010 19:02:51 GMT
Never tried it and may be urban myth but isn't roofing felt supposed to work?
yes ,it started badly ,petered off in the middle and the least said about the end the better!!!
Jan 27, 2010 19:05:02 GMT
Expanding foam/roof flashing and believe it or not under-seal.
fogey
Jan 27, 2010 19:13:34 GMT
I've used a roll of the foil coated rubber undersheet designed for use under laminate flooring - was cheap 'cause I had it left over when I did the lounge floor . . .
alex77
Jan 27, 2010 20:42:19 GMT
Expanding foam FTW had a screwdriver ratting around above the roof of my work transit could not get to it to remove it so used a can of foam. Had to get the roof lining back up sharpish before it would not fit screw driver encased in foam no rattle its a lease van and going back soon I always wonder weather it will ever be discovered and fry someones brain wondering why.
1978 Capri MK2 Ghia Zetec
1990 Ford escort mk4
1996 Nissan Rasheen
1998 Honda CRV (my wifes)
2002 Alfa 156
Jan 27, 2010 20:44:58 GMT
Never tried it and may be urban myth but isn't roofing felt supposed to work? Unfortunately this peels off in hot weather so not suitable for vertical surfaces. OK for use on the floor inside or in the boot floor though.
Jan 27, 2010 20:53:44 GMT
Contact adhesive and carpet underlay...?
Porsche 924 - gone Citroen Saxo VTR - not very retro but I loved it - now gone... MK4 Golf GTi 1.8T - gone but hardly remembered... Mini Cooper S R53 - gone BMW 125d Coupe - gone (mostly sideways)
Ford Focus RS Mk1 - hello low MPGs and "wanna race me" at every set of lights... 1973 BMW 2002 - Twin 40's, 284 Cam, Revolutions, E21 Recaros + more Porsche Cayman 987 3.4S - here and due to cost me more money than I have
Jan 27, 2010 20:57:54 GMT
again fine for floors (so long as it follows the contours) but not ideal for inside doors, quarters, etc.
Jan 27, 2010 21:35:11 GMT
I used some special waterproofing paint on my garage roof that stuck like s##t to a blanket, it dries to a rubbery finish.It might do the job and I brought it at B&Q so its cheep.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
CIH
Jan 29, 2010 22:34:29 GMT
Sorry yeah it's just for under the carpet. I'll have alook round B&Q tomorrow
madmog
Club RR Member Number: 46
I've used old carpet tiles cut to shape under the carpet - the black rubber-bitumen backed things. Might be a fire hazard though coompared to the proper stuff
ChrisT
Club RR Member Number: 225
Sorry yeah it's just for under the carpet. I'll have alook round B&Q tomorrow If you#re thinking about flashing tape (does work quite well) then try screwfixmuch cheaper than B&Q
Jan 30, 2010 18:45:04 GMT
butyl rubber flashing tape is awesome. we use it at work so i keep all the offcuts and use em on my cars
will
Jan 30, 2010 18:51:05 GMT
butyl rubber flashing tape is awesome. we use it at work so I keep all the offcuts and use em on my cars I'll be getting me some of that, thanks ;D
CIH
Jan 31, 2010 19:57:21 GMT
I got some overpriced flashing tape from B&Q as I had left it to the last minute. Seems to work very well, despite running out and only doing half the floorpan d'oh.
Ether
Jan 31, 2010 20:34:04 GMT
Lead flashing is absolutely hopeless. I had it in the Benz - it weighs a ton, is a terrible rust catcher and isn't that much cheaper than Dynamat.
Autoleads do a cheap Dynamat equivalent, as it goes.
