This is a single IDF 44 Down draft carb, came off a 1641cc Dual Port Type air cooled engine, and so it has the manifold and linkage etc to fit this, but can be used on a huge range of engines, with the right manifold and jetting
"The response and tuneability of the 44 IDF is tremendous. You will be able to dial in the carb to your exact needs."
Comes complete with Weber 44 IDF carburetor, manifold adapter and manifold ends for dual port aircooled motor, linkage, chrome air cleaner, and all nuts/bolts etc.
looking for £90 ono, someone tell me if this is reasonable?
Located in Cardiff, South Wales
Can post at buyers expense
I'm on 07903107162 or matt @ llwsc . com
Matty
Matty
