ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Supercharger strapsToolsnTrack
@overdrive
Club Retro Rides Member 134
Feb 21, 2010 20:49:16 GMT
Just saw this after searching to find more info on supercharger straps. Wasnt sure about what they were for, just remember seeing a camaro with them on it. Is this a common thing on massive Weiland chargers? www.streetfire.net/video/Blower-Blows-up-in-guys_26102.htmAnyone got any more info on this? Also, lets see them 'charger straps!!
Feb 21, 2010 21:06:20 GMT
Usually used in conjunction with a 'ballistic blanket' if memory serves me right, to stop all sorts of expensive engine internals turning into missiles.....
'A' series trigger wheels and sensor brackets, 205 GTi radiator brackets, general fabrication and machining - www.gsmotorsport.net
Feb 21, 2010 21:46:29 GMT
Because these type of blowers use fuel to both power the engine and help seal the rotors inside the blower, there is a distinct chance that when you get a backfire, it will ignite the entire lot inside the manifold / plenum. And becuase the blower is so well sealed it can and will shoot the blower right off the engine and a long long way into the air!
The straps and ballisitc blanket are there to prevent it going to far when it does happen.
see here -
That went bang because it leaned out, you can hear the change in exhaust note just before hand.
J
ToolsnTrack
Homebrew Raconteur
@overdrive
Feb 22, 2010 11:59:29 GMT
Good info, cheers for that!
Feb 22, 2010 13:41:20 GMT
I saw one kaboom come off a Budweiser funny car at Santa Pod when I was a kid. It *almost* reached the crowd it went that high ;D
Feb 22, 2010 13:51:53 GMT
"Stuff" comes off these monsters regularly. Usually without incident, thanks to sanctioning body tethers, blow-out panels, plates, fences, and automated suppression systems. But it is still highly dangerous for both fans and drivers. Yesterday a woman in the grandstands at Firebird was killed when a top fuel slick departed from a crashed rail and flew into the crowd.
30psi
Feb 22, 2010 14:04:12 GMT
Seen it a few times at Pod, but the straps do a good job normally. Someone was killed at Santa Pod a few years ago after a ring gear departed from a blown flywheel and went in to the crowd at the end of the strip
1962 Ford Thunderbird 6.4L
1981 Datsun Bluebird SSS CA18DET
1981 Datsun Bluebird SSS SR20DE
Feb 22, 2010 17:03:23 GMT
I thought that was a blower belt at the pod?
J
30psi
Feb 23, 2010 10:54:21 GMT
