All parts are in welwyn garden city, most can be posted, other than the obvious. All prices plus post.
Battery in Boot conversion kit, everything is here, the tray, the cables, inc the little earth one, the cable sheild from boot, grommet, all bolts etc. The only bad thing is the block from the bonnet has a little damage on the bit that covers it, nothing major at all, you could glue it, remove it or source another - £35
Royal Blue Bonnet, very straight, has some marks and scratches - £10
Leads and holder - £12
Rear Lights, rear part included but not in pic - £10
Auto control box from boot - £10
Front Valence, pretty good, some rot on the edges but not terminal - £10
Front ducts - £5
Boot carpet set - £10
Bottom end, has done about 135k, if its been in car from new - £50
Auto Gearbox, car was switchable sports - £100
Below bits are st170
Aircon compressor - £10
Power Steering pump - £10
Thermostat Housing - £5
Alternator - £15
Grill, top part has broken tabs, so its loose, it would glue done and be totally fine thou - £12
Front ducts - £5
Alternator - £15
