Type-9 4WD to Type-9 RWDRobinxr4i
@robinxr4i
Club Retro Rides Member 143
Apr 28, 2010 11:44:02 GMT
Say I had a mk1 Sierra XR4x4 with a type-9 4wd gear box, would a type-9 rwd box be a direct fit length wise? for the prop shaft ect?
Sorry for no cool pics this is only a quick lunchtime request ;D
Gotta get back to work!
Type-9 4WD to Type-9 RWDstealthstylz
@stealthstylz
Club Retro Rides Member 174
Apr 28, 2010 12:00:03 GMT
Oh and why would you want to make a XR4x4 rear wheel drive they're handle really well if you learn how to drive them properly, and can go very sideways.
Matt
Apr 28, 2010 13:41:01 GMT
yup, used to get my old 4x4 ghia estate sideways on a regular basis.
Apr 28, 2010 14:01:01 GMT
You can even fit a RWD tailshaft to the 4x4 main case (saving the cost of a RWD v6 type 9) if you want to
Apr 28, 2010 17:17:52 GMT
Like this one ;D
@robinxr4i
Apr 29, 2010 18:48:40 GMT
You can even fit a RWD tailshaft to the 4x4 main case (saving the cost of a RWD v6 type 9) if you want to I guess that just gets rid of the transfer box? Do you still need a shorter prop? Oh and why would you want to make a XR4x4 rear wheel drive they're handle really well if you learn how to drive them properly, and can go very sideways. Matt I know you can get the xr4x4 sideways and I know they handle well, but I prefer rwd. Drive a few 4wd sierras and I've always loved the 2wd ones more. The way I've looked at it is I can't afford a xr4i and I want a rwd V6 sierra. I've been offered a tatty xr4x4 and I want to skid it, so rwd is what I want to do.
I'm not sure you DO need a shorter prop - I can't 100% confirm, because I haven't ever made an XR4x4 into RWD.. but, that box I built, the one in the picture? After I unbolted and removed the center diff, chain drive and housing from the box, a standard t9 tail fitted it perfectly. The output shaft is the same one, ergo the boxes are the same length. All I had to do to the output shaft was fit a speedo drive gear to it (It even has the machined flat to take one )
Cant remember about the prop length, not that its hard to go look for a 2wd prop if you find out the 4x4 one don't fit.
Its not a bad plan converting a 4x4, they come lowered with gas shocks and LSD and all the toys usually so it saves you adding them your self, easy to fit the 24v to a V6 as well.
Apr 30, 2010 11:23:17 GMT
just a small point (you have probably already have thought of)
you will need to change the sump to steel 2wd one
Someone just shot the elephant in the room.
only the 4x4's with rear discs had lsd's. the type 9 4x4 & 2wd are same length prop, the mt75 4x4 are shorter front half of prop compared to 2wd.
theres more to life than mpg & to much power is just enough.
@robinxr4i
I've brought the Sierra ;D Anyway......... just a small point (you have probably already have thought of) you will need to change the sump to steel 2wd one I was going to get the alloy sump tig'd up. only the 4x4's with rear discs had lsd's. the type 9 4x4 & 2wd are same length prop, the mt75 4x4 are shorter front half of prop compared to 2wd. thanks for the prop shaft info.
I didnt know they did any 4x4's with rear drums, but then i've only had Ghias or XR's so they came with all the good stuff, ya live and learn.
the mk1 2.8's had drums.
Maybe not all of em, my 2.8i ghia estate had discs on the back, you can just about see em here.
