Sinky
Run Baby Run......Please!
Morning all. I'm going to p/u a car tuesday.Its been sitting parked up for about 2 years and wont start .It was a good runner so I belive .Anyway I have put fresh petrol in but I have a feeling the fuel pump maybe gummed up. Can this pump be sorted or am I better putting a new one one. Fuel pump relay? Should I be starting with that first? Basically would you guys start. Its a 94 e200 merc coupe. Thanks
2001 Volvo XC70 wagon
2003 Piaggio X9 Evo
Sinky
May 16, 2010 15:21:03 GMT
Anybody help please
2003 Piaggio X9 Evo
Where do I start?retrowagen1234
@GUEST
May 16, 2010 15:42:48 GMT
might be worth asking on a merc forum as they are more likely to know a defo answer
Sinky
May 16, 2010 18:58:45 GMT
Ok thanks mate. It was just basic info I was after about the fuel pump and only added that it was a merc incase it was maybe somthing to do with the fuel injection. ta anyway
Last Edit: May 16, 2010 19:02:33 GMT by Sinky
2003 Piaggio X9 Evo
May 16, 2010 19:04:36 GMT
does it prime when you turn on the ignition? you should hear it run for a little while as it builds up to pressure.
May 16, 2010 19:05:01 GMT
Quick thing to check is whetehr the plugs have fuel on them or not. If so, then it's probably an ignition problem, if not then it's probably fuelling.
Might be worth a shot of easy start to see if it's fuelling, too.
Sinky
May 16, 2010 21:44:49 GMT
Ok thanks guys . usefull info I will try out both.
2003 Piaggio X9 Evo
Ads 19
My old r19
May 17, 2010 19:44:54 GMT
the 200 engine can be a complete curse word to get going again, i had a 190e that i'd left for 2 years. fuel pump was fine, fuel was defo stale, so drained it and then refuelled. something in the injection does gum up. in end put some brake fluid through it, eventually it cleared enough to get running, only had to drive it 2 miles home because too low for my trailer and it stuttered and backfired all the way.
got it back parked it up, and suprise suprise it wouldn't start. doing the same as before worked out fine. it now starts and runs, but always lumpy and never the same again.n hence why i've been gradually breaking it for spares.
i think only solution is to clean out all the injection kit, maybe couple of bottles of redex injector cleaner as well once your done.
