berny
May 19, 2010 21:40:09 GMT
Quick question for the M.O.T minded peeps out there, long story short is mot due soon and I'm skint due to anniversary, babies birthday and general life ect...... 1 of my tyres is a fail, but the spare is like new, so the question is if i swap the spare for the "dodgy" tyre and leave the spare off the car will it fail? i remember someone telling me if the spares "iffy" it can fail but if its not there it will pass??? is this still correct?
cheers bern
Sammo
Club RR Member Number: 103
M.O.T question?? spare wheel??Sammo
@sammo
Club Retro Rides Member 103
May 19, 2010 21:55:13 GMT
Thats my understanding of the rules. As long as the spare you are fitting isnt a space saver of course
will
May 19, 2010 22:01:16 GMT
My van had no spare at the last test and past and the cars spare has not been searched for in 3 years. All legit Mot's I hasten to add but I'm not 100% on the book definition.
Davenger
It's only metal
Club RR Member Number: 140
M.O.T question?? spare wheel??Davenger
@dminifreak
Club Retro Rides Member 140
May 19, 2010 22:03:31 GMT
Spare wheel doesn't count. The spare in my old mini was bald and flat, never even got looked at at MOT time.
May 19, 2010 22:03:48 GMT
The condition or presence of the spare tyre definitely isn't part of the MOT. Don't worry about it
Last Edit: May 19, 2010 22:04:31 GMT by cobblers
May 19, 2010 22:08:42 GMT
If its not there they can't test it and if its not legally obliged to be present it does not need to be there.
Just like reverse lights front fogs ect.
Leave it at home it'll be rite. (as long as your spare ain't a space saver as previously mentioned)
the spare has nothing to do with the mot however you can get nicked by the old bill for a bald spare
berny
top stuff fellas ;D thats just what i was hoping
cheers bern
Club RR Member Number: 160
M.O.T question?? spare wheel??Rich
@foxmcintyre
Club Retro Rides Member 160
May 20, 2010 11:27:25 GMT
The only thing it could fail on is if the tire is a different size on the spare to the wheel it replaces. Tire sizes have to match across an 'axle'.
May 20, 2010 11:48:59 GMT
The only thing it could fail on is if the tire is a different size on the spare to the wheel it replaces. Tire sizes have to match across an 'axle'. nope thats incorrect
May 20, 2010 12:15:45 GMT
The tyre inspection applies only to those fitted to the road wheels. A faulty spare should be advised if it's noticed by the tester. First inspection point is that all tyres on the same axle must be the same nominal size, so fitting a spare that's a different size will be a fail. All available from VOSA online thanks to the wonders of technology: www.motinfo.gov.uk/htdocs/m3s04000101.htmThe police also can't get you for a faulty spare wheel unless you've fitted it to the car - in which case it ain't the spare any more! Otherwise any time you got a puncture and put your spare on you'd be driving illegally for having a hole in what is now your "spare" wheel
Rob
You know, for kids!
May 20, 2010 12:28:38 GMT
No, its correct That doesn't say 'spare' though does it... Only the tyres on the car are affected by this...
May 20, 2010 14:42:58 GMT
you are still incorrect as that is not refering to the spare only the tyres on the axle
May 20, 2010 15:34:45 GMT
To clarify both tyres on the same axle must be the same size and construction (both radial/xply)
There is also no requirement for a spare wheel in the test, and its presence/condition/size/flavour is of no consequence.
May 20, 2010 16:57:06 GMT
If by using a spare which is a different size to the other on the same axle you will therefore be correct, or incorrect, or whatever
May 20, 2010 17:27:50 GMT
I think Rich is saying that if the current spare is a different size to the current, knackered, tyre then the car will fail if put in with the spare fitted to the car.
In which case, he is quite correct.
Davenger
It's only metal
@dminifreak
May 20, 2010 18:40:12 GMT
It could have a tractor tyre on it, and it still wouldn't matter as fat as the MOT is concerned ;D As long as it's not bolted to a hub, it doesn't count as a roadwheel
@foxmcintyre
May 20, 2010 18:53:19 GMT
It could have a tractor tyre on it, and it still wouldn't matter as fat as the MOT is concerned ;D As long as it's not bolted to a hub, it doesn't count as a roadwheel Pretty much as Davenger said. As stated, spare doesn't come into the MoT test. I was refering to the ROADWHEELS. Hence AXLE pairs? If the spare is a different size as a get-me-home and used to try to get a ticket in terms of being fitted as a roadwheel, it will fail. Never kept my spare wheel bolted to an axle
Last Edit: May 20, 2010 18:53:59 GMT by Rich
May 20, 2010 18:58:53 GMT
Think we've covered this:
1) Spare isn't needed, or checked 2) Tyres must be the same across the same axle.
OK?
