The Gearbox I had built by a mate who has done a few now and always suprised me how much stick they took so i had one built, its a TD scorpio backhalf and gearing with the xr4x4 2.9 bellhousing, very tough box and will take everything you throw at it, will come complete with the shifter assembly, cradle and clutch release arm you just need a rubber mount for the crossmember. Gearbox has also been modified for a cable speedo and the VSS sensor is also fitted. No pictures as of yet as well its a gearbox and I'm sure you all know what they look like but i can get one next weekend if you really need one?
Looking for £220 for the gearbox as ive seen them go between 250-300 when they rarely pop up on ebay, That is collected from cambridgeshire, happy to wrap and courier if you want to talk about that and prices?
Also have a very strong clutch to suit the above gearbox mated to an engine with a 2.9 flywheel, its a transit 2.5TD flat bed clutch 242mm and stronger than the xr4x4 clutches, cost me over £100 new, still in the packaging never been removed or fitted call it £80 delivered.
