Sinky
Run Baby Run......Please!
Hi I bought a cheap clarion cd/radio from a car boot and forgot that when I wired it up it needs a 4 digit code (plonker) Can anybody help please with decode or should I bin it? It was only a fiver but I bought the cable 18 quid to connect so I'm stuck with the cable Model PU-2294A(C) Serial CL040140973872C Its out a pugeot Thanks in advance.
Last Edit: Jun 16, 2010 13:51:42 GMT by Sinky
2001 Volvo XC70 wagon
2003 Piaggio X9 Evo
Sinky
Jun 16, 2010 17:06:45 GMT
Anybody?
2003 Piaggio X9 Evo
Jun 16, 2010 17:17:07 GMT
My calculator gets 4446 but I wouldn't really trust it too much. I need the last 4 digits of the barcode, I'm assuming that is the end of the serial number. Give it a try and if not get me the whole barcode number . If there are two, it'll be the lower one.
Sinky
Jun 16, 2010 17:35:08 GMT
thanks mate Ill try that. there is a number above the bar code 96 392 195 80 the one below the bar code is CL40140973872C
2003 Piaggio X9 Evo
Jun 16, 2010 17:57:30 GMT
Might be 4154 in that case.
Sinky
Jun 16, 2010 20:40:43 GMT
mmmmm..... both no worky
2003 Piaggio X9 Evo
Jun 16, 2010 20:45:16 GMT
Ah, I tried. Thats the best I can do, I'm afraid.
Jun 16, 2010 21:47:24 GMT
My software gave the same answers, are those numbers definately correct?
I also have a program that generates numbers from the position of the diodes??? Wouldn't know where to look for them tho. inside the unit I expect or possibly on the back?
should be 2 rows of 7 or 1 row of 5, good luck with that.
I have a couple of default codes, they don't match your model number but might be worth a punt try 1351 or 2251
Current cars:-
2001 P38 Range Rover 4.0 V8 (economical family run about) 1980 Mini Clubman estate (very much in a state!)rolling shell project 1976 Reliant Robin saloon 1998 kawasaki zzr 600 (the commuter)
