Right I have a little problem.
After making the coil-overs for the Passat I have found that I have about 60mm+ clearance to the chassis but I only have about 50mm travel on the shocks.
So now I want to shorten the body of the shocks. I can do the tubes fine, but... I would rather not do the actual inserts as it is going to be a hassle and potentially messy. so my question is. Is there anywhere you guys know of that I can get off the self shorter bodied shocks? say 50mm shorter? the shocks I'm using at the moment are off a MK2/3 polo but I can also use MK1 golf and i think mk2 golf also.
Obviously I am very tight so as long are they are decent and stiff I want them cheap!
