Jun 16, 2011 20:44:01 GMT
Already tried setting it up with coloutune plugs? Otherwise it might be a leaking seal or dirty jet (Or something similiar, try ultrasoon cleaning) When it goes it absolutly sounds terrific!
I would go for a BMW K(100/1100) injection setup complete with loom, might be a cheap solution. It is untried, but the engine specs are pretty similiar. Still you have a screamer.
Megasquirt isn't expensive so that would be the solution if the ECU wouldn't work with the engine.
So screamer FTW!
Click picture for more
Jun 17, 2011 11:44:28 GMT
This is totally awesome
Jun 17, 2011 15:57:27 GMT
quite possibly my favourite k10, awesome!
Jun 20, 2011 13:51:32 GMT
Thanks for the comments chaps. I have decided that I need to get rid of the carbs so that I can afford to drive it. Iam insuring my driftcar this week so that I have time to pop the micra back onto injection. Iam tempted to turbocharge it though because I still think that injection and boost will still get me decent mpg. When I say screamer pipe, iam talking about external wastegate vented to atmosphere Like this Excuse the poor driving, bad day and tyres down to the metal lol
Carbs, manifold, modified dizzy setup are now for sale
Drop me a pm if your interested in any of them
Already tried setting it up with coloutune plugs? Otherwise it might be a leaking seal or dirty jet (Or something similiar, try ultrasoon cleaning) When it goes it absolutly sounds terrific! I would go for a BMW K(100/1100) injection setup complete with loom, might be a cheap solution. It is untried, but the engine specs are pretty similiar. Still you have a screamer. Megasquirt isn't expensive so that would be the solution if the ECU wouldn't work with the engine. So screamer FTW! I payed to have it setup on the rolling road and they made an improvement but still not right. It does sound great when its going I have a megasquirt already, but I tried to fit it to my suzuki swift engined mini and couldn't get it to work properly. I gave up on the whole car in the end and now its sat rotting away. Iam getting the standard injection setup and fitting that for the next few months, eventually I will get a nistune ecu and get it fitted and mapped by greg at protuner. He is doing my 200sx next month. Ill most probably go down the turbo route because I have almost everything I need/want.
Sept 1, 2011 10:36:17 GMT
Last Edit: Sept 1, 2011 11:10:50 GMT by swiftmini
Sept 1, 2011 10:43:52 GMT
Last Edit: Sept 1, 2011 16:52:47 GMT by swiftmini
Sept 1, 2011 11:20:02 GMT
pics arent working for me mate? :-(
Sept 1, 2011 12:48:23 GMT
Oh poop ill see if I can fix them tonight
Sept 1, 2011 16:54:47 GMT
i cant work out whats wrong with my pics. i copied and pasted my whole posts from another forum, same as i always do and they're not working. i looked at previous posts and the pics are still they're and posted in the same format :S
Sept 2, 2011 21:43:49 GMT
Going by the one previous pic I just looked at you're using picasa? I've found it sometimes gives https, delete the s so it is just http and it normally works again.
thesam
Sept 2, 2011 22:48:19 GMT
so so so good
craig1010cc
Club RR Member Number: 35
Sept 3, 2011 11:03:28 GMT
craig1010cc
Sept 3, 2011 11:05:02 GMT
There you go, it is HTTPS
so here is a run down on what i havbe done in the last week that i have been working on the car again. I went to the scrap yard and bought. (my engine is a cg13de (1275cc)) cga13 inlet manifold (cga is later coilpack engine and 1350cc) cga13 fuel rail cg13 dizzy and coil (all one unit) cg10 wiring loom and ecu (cg10 is 1000cc but more aggressive mapping) cg13 sensors ect cg13 tb and maf setup (all one unit) ga16 airbox (ga is almera engine) cga13 valves (2mm longer stems for high lift cams) qg18de injectors (211cc from a nissan serena) also i have the kent cams and hi compression pistons as you can see in the above pics i have made an adaptor plate to fix the sr20 throttle body onto the cga inlet manifold. i then machined the cg13 throttle body/afm setup until i was left with just the afm. then i araldited them together. i need a more suitable fixing solution for long term usage.
Davey
Resident Tyre Nerd.
Sept 4, 2011 10:52:10 GMT
Glad you managed the rev-limiter delete, seems my help on the other forum actually helped for once!
Sept 4, 2011 21:47:17 GMT
yeah thanks for that man
