Aug 16, 2010 14:14:56 GMT
In Sheffield although I do travel up and down the M1 sometimes. tobucket.com/albums/r237/samwell89/CIMG0676.jpg[/IMG] Small compressor (Regulator is Condor MDR 4/11 500V- 5.5kW 16A, 11bar, no deets on the motor), got loads of accessories including new! 10m hose, grit blaster, tyre inflator, dremel (+stones), mac tools 3/8" gun, beasty 1/2" gun. Its wired through resetable trip to stop it blowing fuses as its on the limit of home use. Just seen its missing 1 female 1/4" bsp fitting to use. £90 OVNOSOLD pending meeting boiler suit £4 posted! good for slim people up to 5'8" or reduce depending on width... Thanks Sam
Last Edit: Aug 31, 2010 11:39:48 GMT by samwell
'88 Toyota Supra Turbo
'88 Honda VFR 400 NC24
Aug 16, 2010 18:22:55 GMT
Any idea of specs for the compressor? Thinking of airflow (CFM) or, if not that then some sort of model number / name.
Aug 16, 2010 18:31:20 GMT
Really nice 10cm inPhase £30 Posted?
Aug 16, 2010 20:58:57 GMT
all known details of compressor added, not ssure what to make of the "500V-" marking as it runs happily on mains. In Phase Speakers are on eBay, I think I will realise more than that. Else I come crawling back. "Go Fish" nutroast
Aug 16, 2010 21:14:18 GMT
Aug 16, 2010 21:44:41 GMT
The part you've put in "Condor MDR 4/11 500V- 5.5kW 16A, 11bar" seems to relate to the motor control pressure switch rather than the compressor itself. That would explain the 500v bit too, ie the max voltage the switch can manage. Details of them here - www.condor-usa.com/products/condor.htmIs there anything written on the compressor itself? Even model number+google usually is enough to find specs.
Aug 17, 2010 18:45:16 GMT
The part you've put in "Condor MDR 4/11 500V- 5.5kW 16A, 11bar" seems to relate to the motor control pressure switch rather than the compressor itself. That would explain the 500v bit too, ie the max voltage the switch can manage. Details of them here - www.condor-usa.com/products/condor.htmIs there anything written on the compressor itself? Even model number+google usually is enough to find specs. Sorry but I can't seem to find any other markings except for the pressure vessel certification. I have just found the instructions from the guy I got it off which mentions 8bar as the max suggested pressure. The tank was make in June 1989, its the same age as me...
Aug 19, 2010 17:19:53 GMT
sorry nutroast, I was obviously feeling cryptic when i posted. I think I was suggesting a slightly higher offer might be accepted. Anyway, speakers are on fleabay (320576891144) with a few days to go. Price drop on the compressor as I think I was being a bit optimistic. Sam
Aug 20, 2010 13:45:44 GMT
mad sneaks added
Aug 24, 2010 17:49:57 GMT
stuff sold, price drop on compressor
compressor sold pending meeting.
overalls free, can post for cost.
Sam
eloise
Aug 26, 2010 17:09:44 GMT
if the compressor sale falls through, could i come and have a look at it please.
