J1MMY
Jan 26, 2011 22:32:03 GMT
Wow, this conversion is going to be interesting What is the difference in the height of the blocks and the gearbox sizes? One other thing - what were the donor wheels for the banding exercise?
Your opinion is invalid, I've seen your wife.
Jan 26, 2011 22:55:56 GMT
a nice swap to do and it'll really transform your car. will be intrested to see how you develope this. will you do the same as we did and drop the x/member clean mount and build new mounts off it or do you plan to mod the sx engine mounts?
Copey
Jan 27, 2011 12:39:16 GMT
i am using SX engine mounts, lower the crossmember and inch to clear the bonnet, annoyingly i cant just mount the engine lower due to the stupid front bowl sump! with 10mm thick plate to mount it to the capri crossmember and then a brace under each mount, gearbox mount will be made of a combo of the sx mount and capri mount chopped and welded jimmy, i will upload more pics of the engines together, they are pretty much the same size and the wheels are from a mondeo
Copey
Jan 27, 2011 12:45:19 GMT
engines together as you can see, not far off at all and this was yesterdays work there are few rusty bits that will need a little attention, leading edge of the battery tray for one, but no biggie
J1MMY
Jan 27, 2011 23:07:10 GMT
Awwww, this is going to be awesome can you notch the crossmember and chassis mount? *shrug* Mondeo steels....no inner clearance probs? The OSF lot always seem to moan about inner clearance issues.
Copey
Jan 27, 2011 23:37:58 GMT
yeah, there is, but i modded my exhaust to suit, they do hit the front struts sadly, but hubcentric spacers have sorted that, but i think i am gonna be gettin another pair done with 3" band on the outside and 1" cut out the rears
and "notch" crossmember?
J1MMY
Jan 27, 2011 23:49:07 GMT
If the sump bowl interference is minor, shape and re-weld the crossmember around it? Done right it would keep its strength and you could sit the engine lower but obviously if the interference is significant I wouldn't want to cut too much out of it. Just a thought, seen similar done before.
EDIT - scrub that, the rack is in the way. Forgot that the rack is in front. *facepalm*
Last Edit: Jan 27, 2011 23:50:26 GMT by J1MMY
Copey
aye mate, sadly is it! annoying thing that it is! i will sort something at any rate
Copey
Jan 28, 2011 13:19:58 GMT
big ass FMIC came today lil bit fat
Jan 28, 2011 14:16:57 GMT
That looks familiar
Copey
Jan 28, 2011 15:46:22 GMT
aye dave, same as yours £80 from ebay
sasky
Jan 28, 2011 22:25:15 GMT
Will be interesting to see this built. will you be stripping the loom down? we took out about 3 tesco bags of wiring and a bag of tape. so many wires going to the back that you just don't need on the capri. talk to spitsx he did mine for me (mint job aswell). Dave u got ur capri up and running yet? hopefully will be some capris at the gathering this year
Copey
yeah mate, the loom will be gettin stripped of pretty much everything, I will use the engine part of the loom, some of the clock loom and the loom for the fuel pump. Lights, aircon, door locks, interior lights, electric windows etc etc will all go
will be fairly basic when I am done
Last Edit: Jan 29, 2011 0:30:44 GMT by Copey
Got mine runnin Tim, fully rebuilt it but only run for about 10 minutes as the fan wasn't playing! got to sort that then I can MOT it. Ill deffo be at the gathering having a go of that hillclimb in it!
Copey
Jan 30, 2011 18:38:58 GMT
Jan 30, 2011 20:41:28 GMT
Nice one dude coming along nicely - a word of warning! You havent finished grinding that b!tch! I had the same isse with the wideness of the cooler but cut through the inner wings to house my pipes. Gonna pull the car out again and take some proper photos with my DSLR to bump my enthusiasm up in the next couple of days. Seeing you get stuck in is helping get my chin up Whats the next plan then? If you need any info/help giz a shout Tom.
Copey
Jan 30, 2011 20:59:52 GMT
great stuff, thanks Dave appreciate it mate and yeah, i dare say i will need to get busy with the grinder again hehe, 2moros job is engine dangled in and mounts measured up fun times
moorey
Jan 30, 2011 22:59:12 GMT
Hi its a great conversion going to be useing this engine myself soon have you thought about putting the battery in the boot to ease up some more space and a cleaner look. john
Copey
Jan 31, 2011 20:27:13 GMT
moorey, i have thought about it, but not too sure, got some thinkin time so maybe well its all dangled in and lined up, next up mounts, had hoped to get them done 2day, but my mate Si was busy today, so they will be done 2moro
Copey
on its mounts and then engine out again to take the crossmember off to weld on the mounts and brace them properly also took the seats out and the carpets up, had a good stab about with a screwdriver, found a couple of holes which shall be sorted while its off the road nout bad, the drainage plugs have rotted...stupid idea them things!!! and a couple of other lil bits, easy fix
