Been lurking for a while and thought it was about time I contributed to the forum
Yesterday I acquired this Briggs and Stratton engine for ebay for the sum of £20. My aim is to clean it up and connect it to an alternator/generator so I can have some power in my garage.
It turns over nice and freely but I could see that there was some crud in the cylinder, so whipped the head of to find this.
After a bit of elbow grease the block and head came up lovely. You can't really see in the picture but the bore is in near perfect condition. The piston also has .20 on it, although I'm not sure if this means it has been bored out or not.
Anyways, I moved on to checking the ignition system. The first obvious problem was that someone had put too long of a spark plug in and the spark plug gap had closed up when it came into contact with valve. Connecting up the spark plug, i turned the engine over, but still no spark. So I checked the coil and found that the contact breaker points were not opening. After a brief strip down of the flywheel/fan, I found that the dowel that opens and closes the points had swollen up and seized into the hole.
After a quick bit of drilling a managed to remove the old dowel and replaced it with some brass rod I had lying around.
And thats as far as I got today, hopefully put it back together tomorrow and see if I can get it running. Anyone have any info on these engines? Especially why there would have been a wooden dowel to open the points?
Gary
Gary
