Bought a 1985 nissan 300c estate recently and I don't have a key to fit any of the doors just one for the ignition. What options do I have and can anybody help me? Repin locks to match ignition key?? Try and find somebody breaking one to get a lock set?? Need help asap with it as I don't like leaving cars unlocked it doesnt feel right to me. have some pictures
Last Edit: Sept 8, 2010 9:08:45 GMT by Hudzoyne
93fxdl
Enter your message here...
Sept 8, 2010 11:03:26 GMT
a couple of suggestions try the yellow pages for a local locksmith and see if they can help fit an aftermarket central locking system (dosent help with igition though) contact a nissan dealer to see if they can help (some manufacturers keep records of key numbers and can cut keys from those numbers) are the lock barrels the same as any other nissan models finally and the most brutal take out the lock barrels insert any key which fits in and file off the protruding pins ttfn glenn
Sept 8, 2010 11:33:17 GMT
I think the locksmith could be a good bet. In xb0ll0ck's tat blog his Mazda had no keys and he took the ignition barrel etc to his locksmith and they managed to make up a set for it. It could be worth taking out one of the door locks and trying the same thing.
Sept 8, 2010 11:56:43 GMT
Older Nissans often have the key number on a label inside the glovebox. Nissan can cut you a key from this, in fact they may even be able to do it from the VIN#.
Datman on here might be able to do one from number as I believe he has the code books and cutter, providing blanks are available. he may even have some used locks with key.
Sept 8, 2010 12:07:45 GMT
i was thinking of something along those lines but i didnt think i could be done without some stupid over the top charge.
Key blanks can be had on ebay for £1 odd so no expense there.
Sept 8, 2010 12:14:52 GMT
They're not cheap from Nissan. About £15 IIRC.
Sept 8, 2010 12:26:08 GMT
probably best off buying some blanks then? and getting somebody to cut the keys to fit the locks?
