when I go to...
www.retro-rides.org
I get this.....
www.retro-rides.org
I get this.....
Server Error in '/' Application.
Recursive fallback not allowed for character \u003F.
Parameter name: chars
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentException: Recursive fallback not allowed for character \u003F.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[ArgumentException: Recursive fallback not allowed for character \u003F.
Parameter name: chars]
System.Text.EncoderFallbackBuffer.ThrowLastCharRecursive(Int32 charRecursive) +126
System.Text.EncoderFallbackBuffer.InternalFallback(Char ch, Char*& chars) +262
System.Text.SBCSCodePageEncoding.GetByteCount(Char* chars, Int32 count, EncoderNLS encoder) +7601150
System.Text.EncodingNLS.GetByteCount(Char[] chars, Int32 index, Int32 count) +104
System.Text.Encoding.GetBytes(Char[] chars, Int32 index, Int32 count) +24
System.Text.Encoding.GetBytes(String s) +38
System.Diagnostics.EnvironmentBlock.ToByteArray(StringDictionary sd, Boolean unicode) +337
System.CodeDom.Compiler.Executor.ExecWaitWithCaptureUnimpersonated(SafeUserTokenHandle userToken, String cmd, String currentDir, TempFileCollection tempFiles, String& outputName, String& errorName, String trueCmdLine) +914
System.CodeDom.Compiler.Executor.ExecWaitWithCapture(SafeUserTokenHandle userToken, String cmd, String currentDir, TempFileCollection tempFiles, String& outputName, String& errorName, String trueCmdLine) +122
System.CodeDom.Compiler.CodeCompiler.Compile(CompilerParameters options, String compilerDirectory, String compilerExe, String arguments, String& outputFile, Int32& nativeReturnValue, String trueArgs) +195
Microsoft.VisualBasic.VBCodeGenerator.FromFileBatch(CompilerParameters options, String[] fileNames) +466
System.CodeDom.Compiler.CodeCompiler.System.CodeDom.Compiler.ICodeCompiler.CompileAssemblyFromFileBatch(CompilerParameters options, String[] fileNames) +197
System.CodeDom.Compiler.CodeDomProvider.CompileAssemblyFromFile(CompilerParameters options, String[] fileNames) +25
System.Web.Compilation.AssemblyBuilder.Compile() +775
System.Web.Compilation.BuildProvidersCompiler.PerformBuild() +71
System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) +8729739
System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) +261
System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) +101
System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert) +126
System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert) +62
System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath) +33
System.Web.UI.PageHandlerFactory.System.Web.IHttpHandlerFactory2.GetHandler(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath) +40
System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig) +160
System.Web.MapHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +93
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155
Version Information: Microsoft .NET Framework Version:2.0.50727.3615; ASP.NET Version:2.0.50727.3053
Source Error:
Stack Trace:
