Looking for swaps for cars or good cash offers!
Fully forged, Sierra XR4x4i 3litre V6 on a Single Turbo (HOLSET Truck turbo)
Since built its been run in, with 2 fresh oil changes.
Turbo Technics top inlet chamber, polished internal.
Solid block, machined, honed. Better core plugs.
Fully powder coated Engine/Parts/Components.
Stage 3 Ferriday gas flowed cylinder heads/ port polished inlet & outlets with sodium filled exhaust valves.
Chrome rocker covers.
High torque/lift camshaft + group a valve kit, oversized oil galleries.
JE Forge ceramic coated pistons, Balanced Steel 'H' beam con rods with fully floating small ends.
Electronic waterpump
Girdled sump which bolts up through the sump into the main case strengthening the bottom end allowing the engine to rev round.
Bottem end has had work, Lightened & Balanced, flywheel.
Billit machined crank, Oil squirt rail fitted + YV oil pump drive, wet sump.
Siemens deka 630 high pressure injectors
Cometic steel gasket set and 'o' ring set
Mocal oil cooler, Oilstat-10JIC
Various uprated Braided hoses and pipes.
Red Magnecor HT Leads
+ Loads of other odds and sodds....
For the running in process its had a Garret T4 Turbo and stock exhaust manifolds fitted, ideally for the true power you should have a custom set of manifolds made. I have a Holset Turbo here to go on instead of the T4. Iv also got a Uprated actuator.
4X4 Gearbox is Reyland big tooth straight cut box. Brand new and powdercoated
Quaife ATB machined Diffs, brand new and powdercoated
All 4 drive shafts, Antiroll bars, Balanced prop-shaft, Pollybushed up, Subframe, Uprated fuel pumps & Coil pack, Brand new whishbones and hubs. Backend cradle, Fuel tank, Brand new steering rack, Brand new starter motor, HKS Bov.....etc etc
EVERYTHING is either Brand new or Reconditioned and powdercoated!
Has been run on Antilag and Launch control
With the spec of engine, on the holset using right management it will see 600bhp without probs. This engine is built to be withstand high power and to be as reliable as possible. It is sold as an Excellent runner!!!!
PICS
img814.imageshack.us/img814/8055/img6188t.jpg
img442.imageshack.us/img442/5369/img6187u.jpg
img820.imageshack.us/img820/5936/img6193rg.jpg
img826.imageshack.us/img826/9590/img6189q.jpg
img30.imageshack.us/img30/6730/img1304ba.jpg
Heres something simular, less spec tho:
PICS
