Oct 30, 2010 15:12:52 GMT
I'm looking at replacements for the busted fuel tank in the Bond. A Land Rover Series under-seat fuel tank looks like a good candidate, but I could do with knowing the general dimensions. Does anyone have a tank they could measure up for me? Bit of a long shot I know...
task
Oct 30, 2010 15:18:04 GMT
I can measure mine up tomorrow unless some one else beats me to it
Oct 30, 2010 16:00:32 GMT
(A) they are quite heavy gauge steel so weigh quite a bit. (B) if you do go for LR tank only consider new (cheap) as they are double skinned on lower panel and rot between the layers even if they look sound from outside.
Paul H
Oct 30, 2010 16:07:24 GMT
Task - if nobody comes up with the figures today, that would be great if you could! Thanks. Composimmonite - New tanks are so cheap it hardly seems worth getting a 2nd hand one. My tank is fairly weighty, so a little more weight won't hurt - it might keep the back end planted a bit more! ;D
Oct 30, 2010 16:39:53 GMT
i can, but not til mon, if no one else comes through!
LowStandards
Oct 30, 2010 16:56:33 GMT
I've just been under mine for ya Dean
Its: H - 13" - 33cm W - 12" - 30.5cm L - 23" - 58.5cm
Its pretty damn compact and very square!!!
Oct 30, 2010 17:04:26 GMT
Yer a star! Thanks very much mate!
LowStandards
Oct 30, 2010 17:09:31 GMT
No drama!
Just looked at your mockup in your thread, seems its fits everywhere bar its length. Is the old tank angled to fit over summat, or is there space to squeeze it in?
Oct 30, 2010 17:13:02 GMT
Yea the tank is angled to avoid the wheelarch. I am thinking of mounting the tank in the middle between the arches. I'd get back the boot space left by the old tank that way.
If I got a tank to fit where the old one was I reckon it'd be quite small as I'd never get an angled tank like the original, and I don't fancy constantly filling up.
Landy tank is prime candidate at the moment!
