Oct 30, 2010 18:29:12 GMT
the PCD (4x108)is the same.. but is the center bore?and what sort of offset thay got? do thay fit on a FWD ford?? seen a cheap set and think thay would look good on my next project ;D
RobinJI
Oct 30, 2010 19:22:01 GMT
According to This site, the saab wheels have around a 5mm lower offset, and a 1.9mm larger centre bore, so they should be a pretty good fit, although spigot rings could be a pain with a centre bore difference that small.
kee
Oct 30, 2010 19:29:00 GMT
robin had some saab wheels on his sierra and it looked fantastic
Oct 30, 2010 20:03:04 GMT
Oct 30, 2010 20:06:45 GMT
If you go onto uksaabs,you find 15" cross spokes easy to obtain,but 16" like poor quality wobbly children's play pony droppings.
saab wheels on a ford..??Robinxr4i
@robinxr4i
Club Retro Rides Member 143
Oct 30, 2010 21:44:00 GMT
robin had some saab wheels on his sierra and it looked fantastic Yes I did........ I used normal 60 degree tapper bolts and didn't use spigot rings. I had no problems! As for the offset the Saab wheels are a little lower than your average FWD Ford wheel, but not by loads, you shouldn't have any problems with clearance.
You're basically looking at saab 900/9000 wheels made 88-97. The correct ones have an extra 'locating' lug, it can be confusing as they did similar wheel styles using the earlier triumph PCD. Oh and modern stuff is 5-stud vauxhall...
'98 e36 316i lux '97 mx5 harvard '87 Saab 900 T16s
I have a set of those fitted to my Audi 80, they too have a pcd of 4 x 108 but have a much smaller centre bore, so I will be fitting spigot rings. They also stick out further but not by much.
So do saab wheels fit a peugeot, with ford and pug having the same fitment?
conrad
Here to fix your cabin.......
if it's a peugeot with 4x108 pcd and not the 5 stud or 3 stud ones then it should yes. Seeing as you can put peugeot wheels on a sierra, and saab wheels, should work the other way around
edit, i must add not all saab wheels are 4 stud though
Last Edit: Nov 5, 2010 13:10:18 GMT by conrad
Earth Rocker
Among the living.....Just!!!
Keep an eye out as well for pre 87 Saab alloys, because the handbrake is on the front and will not fit.
Yeah I didnt really elaborate the question, peugeot is 4x108 thanks for the reply.
