Dec 29, 2010 14:34:43 GMT
Hi all,
Have got a set of 2nd hand suspension springs, and the original coating is flaking off. I want to apply some pretty permanent rust protection, and it seems that powder coating might do the trick. Is this a good idea? Will it last long with the flexing of the springs? If so, does anyone know of a good powder coating place in the S. Wales area? Google throws up a few places but I wondered if anyone could recommend somewhere good/cheap.
Thanks in advance!
Dec 29, 2010 14:38:36 GMT
Powder coating is okay on springs where there's little deflection (ie stiff ones). Generally big springy ones use plastic coating.
bstardchild
Club RR Member Number: 71
Dec 29, 2010 14:40:17 GMT
Hi all, Have got a set of 2nd hand suspension springs, and the original coating is flaking off. I want to apply some pretty permanent rust protection, and it seems that powder coating might do the trick. Is this a good idea? Will it last long with the flexing of the springs? I've done it with loads of springs - hangs on pretty well - better than wet paint IMO
Dec 29, 2010 14:42:20 GMT
I think the springs for my car fall into the "big springy ones" category. Can you tell me a bit more about plastic coating? Ta.
Dec 29, 2010 14:46:28 GMT
I think the springs for my car fall into the "big springy ones" category. Can you tell me a bit more about plastic coating? Ta. From what I recall from A level DT it involves heating the metal up and dipping it into a trough of plastic beads/powder. Similar to powdercoating but you and up with a much thicker and more flexible coating.
Dec 29, 2010 17:53:41 GMT
I've had motorbike springs plastic coated and looked OK for years. I wouldn't be surprised if the existing flaking finish is powder coating. All it needs is a nick that allows water in and it'll rust under the finish until it flakes off. Personally I'd just use decent primer / paint as easy to redo every so often whereas plastic or powder coating is difficult to remove (chuck in fire ?) if it deteriates.
Paul H
Dec 29, 2010 18:41:07 GMT
Striped with a knotted wire wheel in the grinder then rust treated then sprayed using red enamel from a tin.
Dec 29, 2010 18:54:31 GMT
castle coatings in caerphilly, good guys and they have a few classics there.(one of my old imps is there) ask for chris.
tell him aled sent you.
too many cars so little time. hello boss i have a problem- work is getting in the way of my hobby.
Dec 29, 2010 21:21:00 GMT
plastic or powder coating is difficult to remove (chuck in fire ?) Somebody will know the science better than me but I'm pretty sure this is a bad idea - something to do with spring-steel becoming steel when you get it really hot?
