Foss
Feb 10, 2011 13:21:39 GMT
Looks like a great job on the body. I always like to see that people can get good results with good old spray cans!
I used to get a lift to my under 11 football in one of these as a kid and I remember it seeming like the fastest thing ever.
Feb 10, 2011 13:48:13 GMT
Nicely done... It looks awesome...
75nut
Feb 10, 2011 13:51:29 GMT
Cheers guys very kind! Lay it on thick and then you got plenty to cut back ur mistakes on lol!!
90 Alfa 75 3.0 V6 Cloverleaf 79 MGB Roadster 88 Saab 900i Convertible 94 MK1 MX5 1.6 05 Volvo V70
levismerc
Learning all the time...
Feb 10, 2011 14:04:24 GMT
Great work. I like these old Saabs and yours looks really nice now.
'83 Merc 280CE
75nut
Feb 10, 2011 14:42:55 GMT
Cheers Levis! Ordered the headliner fabric now so going to sort the interior. Seats are great so only a real good clean needed. GOing to try a dash repair kit to sort the cracks, don't know if anyone has had any experience using them and has a tip??
75nut
Feb 13, 2011 14:25:47 GMT
Got bit more done this Sat (unfortunately no playtime Sunday!) started with the cracks in manifold that I think are causing the lumpy idle, and blowing sound in engine bay. Decided to try JB Weld as a stop gap til I get a manifold and the time to fit it. But if it worls, well you know what the say about temp fixes lol! Ground down the areas and used dremmel to try and V the crack a bit and give the JB better grip. Applied it with a lollypop stick and then a finger (rubber gloved of course) to smooth it in and push in tight to crack. As it takes 16hrs at least to dry don't know the results yet, so cracked on with (fingers crossed) the last bit of rot to resolve, the driver door bottom, some big holes to sort Stripped door only takes a second and saves any burning etc Got wire brush and flap wheel on to see how bad it was Bad, so only anwser was to cut entire strip out along bottom to good metal, only left few inches nearerst door that was good Small section in the edge of door needed replacing so bit of zinc coated metal mole gripped inot place Smal spots to hold then seamed between (been taking notes and advise from BMW Tony and taking my time), and after a flap wheel run over a near invisible join, pleased with that, cheers Tony! Not absolutely invisible as Tonys, so will keep practicing, plus I am using gassless which I hear is bit harder to be clean with. don't know why I left it long with the idea Id hammer back the return edge, would have been much easier to form before hand, but all a learning curve eh! But then , damn it, ran out of metal long enough for repair full length of door and shops 40 mins away with daylight getting short, only thing to do, hack into a rear panel from MGB, where I had replaced the entire panel with brand new, glad I kept it now! Flap wheel and coate din zinc it was great metal and good thickness. Good thing was it had a nice curved edge to match the door. Again tack it and then seam inbetween, but rushed to much and over trimed at the far end so had to big a gap than I was happy with, so no choice other than trim the section I was happy with read to fill in the rest another day! Coated in rust proofer ready for finishing and grinding another day
Last Edit: Jun 22, 2011 19:45:10 GMT by 75nut
75nut
Feb 28, 2011 15:31:42 GMT
Well little update. Finished and painted the bootom of the door so nice and solid there again. Cleaned up the door card while I was at it and pleased to see the beige fabric came up lovely so a good sign for the rest of the interior. Headliner roll arrived so ready to tackle that. But then a little issue arose, being a load of white steam from the front and lumpy idle. My missus remindered me we get the top cover from AA on our bank acocunt so rather than diagnose it myself I called them lol! They came round and discovered a hole in the rad and it was the coolant causing the sick smelling smoke. Luckily I had not driven far and it had not overheated so avoided a big bill there! He also discovered the coil was shorting accross the points hence the idle. So a shopping spree was required (some needed some just wanted! lol) - New Coil and lead - New chrome trim for bumpers - New mast for broken ariel - New boot badge to match the front one - New Rad - no pic as not arrived for weekend unfortunately! So lots to fit, but need to clean up the flaking laquer on the rear bumper first and re do as will let everything else down, any tips greatly recieved! Should be a beaut when this is all done and healiner in (oh and have the dash repair kit to fill some cracks),
Last Edit: Jun 22, 2011 19:46:16 GMT by 75nut
Feb 28, 2011 17:12:12 GMT
My Dad used to have 1 of these....used to love driving it......very solid car....if you hit anything..they will come off worse....and loved the position of the ignition key....didnt it used to lock the gear stick or something? and didnt the handbrake work on the front wheels? ?
75nut
Feb 28, 2011 20:53:50 GMT
Not sure bout the Handbrake, I'l look, but yep the car has to be in reverse to remove the key
Feb 28, 2011 21:07:07 GMT
Pretty sure it was the front wheels
How did the JB weld work out on the manifold?
Front handbrake is on pre 1987 cars, so this car could be one but may not be. If the PCD is 4 x 108 its rear handbrake. Front handbrake cars are 4 x 114.3.
75nut
How did the JB weld work out on the manifold? Its gone kinda brown colour now from the grey, since I ran the car. But it seems to be holding wih no cracks or blow through.
Great job, I love thest old Saabs reminds me of my summer working for Buckingham and Stanley in Cambridge when I was 17
75nut
Last Edit: Jun 22, 2011 19:47:12 GMT by 75nut
75nut
Mar 13, 2011 22:31:19 GMT
Got on finishing the headliner and parcel shelf this weekend (much to the wife's pleasure lol!) First needed to remove the sunroof and cover that as according to the guide I was using it needs to go back in before the healiner. Came out pretty easy following the instructions. So then just needed to have the fabric glued on. You only glue the edge to fold over, not the whole thing - Took the oportunity to remove the wind visor as easier to get everything out and gave me a chance to clean it underneath, years off dirt there! Cleaned off the deflector too good chance to get the underside clean Before I started putting things backin decided to add this Figured it would help get any marks off that might occur putting stuff back in, especially round the greasy sunroof runners, added it to everything including parcel shelf and full liner. Then put sunroof back in , again fairly simple. At first it would not go back all the wy when tested, but fix s one of the ruuner guides had slipped back during tightening of the nuts. Time to put the headliner back in, very very nervously due to the break getting it out! It did bend a bit but thankfully held together and got better and better as I added the fittings back in.The sunroof whole is not cut til the headliner is in ad the material is gule over both the headliner edge and the sunroof frame. Adding the fittings back was the toughest part of the whole job (or it was just late and I was tired!), just a right pain trying not to cut back too much fabric but as the same time locating the screw holes all in cramped space!Put recovered rear shelf in too (left out the 6x9 for the mo as the don't have grilles and don't like the look. That was enough for Sat so after a big bravery breakfast went out to cut open the headliner around the sunroof hole. You glue it back over the headliner and sunroof frame then add small clips over which the finsihing rubber trim is lightly tapped back over with a hammer. So started with this - And finished with this (an only a few creases here and there lol!) My first time ever so not too ashamed, but next time will be mint lol!! Next time to clean the interior all over as loads of old foam bits from headliner etc and use the dash crack reapir kit, intrested to see how that works out
Last Edit: Jun 22, 2011 19:47:58 GMT by 75nut
75nut
Mar 22, 2011 18:32:35 GMT
Got new Rad in this weekend, not as simple as thought was going to be as what I had seen online was refering to 2.0 not a 2.0 Turbo so some turbo pipes had to come off. Also fitting the new coil and got a much better idle now.
Next up is a bloody good clean and then off to a proper mechanic to sort the blowing from the engine bay, either a gasket or crack I recon.
The Alfa is spewing fuel at mo so I'm back to driving a the Jeep, which is no where near as enjoyable!! Doe snot oversteer as well as the 75 lol!!
RetroMat
Column Shifting!
Mar 22, 2011 19:38:51 GMT
Looks all very familiar ;D Especially the arch repairs! Great work with the head lining i'm tempted to attempt the same soon as mines full of drawing pins: ;D ;D ;D ;D
75nut
Mar 23, 2011 13:45:22 GMT
Lol, a love all th epins, thats what I found on the Saab too! Fidly job and you need to leave a day or two and take ur time but well worth it! Took her off to Steve at Miltern Dammerel Classics today to get the exhausty noise looked at. Turns out he is a big Saab nut (as well as Alfa!) and can't wait to get his hands on her. Seems my thoughts where right and its the gaskets on the manifold and turbo system. As the bolt are likely to break in the head I'm having him do the work next week, and is going to tinker with the wastgate to as he has a few tricks!
75nut
May 23, 2011 13:24:39 GMT
Got the Saab back from MDC and he did the job! Got loads fo boost now, great wastegate noise and huge midrange torque! But a bad sweet smell and steam from egine indicated a dead rad so got on fleabay and sorted another. Got the old one out (my first diy rad replacement) but required more pipes moving out the way than on the non turbo instructions I had seen online. New on seemed to have a much deeper fan housing but less blades, so tohught best thing to do was to swap them over (new on left) Swapped And plumbed back in Note the new coil, replaced the dis cap,rotor arm all leads and new spark plugs at same time and there seemed to be a little misfire before. Ran alot better but also had a slight hestiation could not work it out. Filled up with super unleaded rather than standard and seems to have cured it, should this be on leaded fuel?? THinking time may of come to sell, the 900 it wa san impulse buy, as always now she works fine and needs nothing I hanker for something different, Anyway, added another car to the yard this week, a MK1 Mazda MX5 1.6! Saw it local cheap and could not resist. Turns out the power steering issue was a burst pipe which was £200 at Mazda. T Cut and wax and she is a beaut, loads of history and drives sweet as a nut, understand why people love em, that 1,6 and gearbox are so sweet a combo!! £2 of fuel pipe and some clips fixed the power steering Lol! Works perfect! Pics to follow will start a new thread. The 75 is currently sulking due to lack of use and as always when you don't abuse them regularly something breaks! She had poppped her rear spoiler light so another fix needed!
Last Edit: Jun 22, 2011 19:48:50 GMT by 75nut
