75nut
Just got this to join the Alfa on Ebay. Was an impulse buy on Ebay tonight so got to pick it up and check not a complete shed. Its a 8V Turbo with an Aero kit from the factory and FSH. It's cherry red despite looking brown. Wish me luck Ill post more pics when I get it.
Last Edit: Jun 22, 2011 19:37:26 GMT by 75nut
90 Alfa 75 3.0 V6 Cloverleaf 79 MGB Roadster 88 Saab 900i Convertible 94 MK1 MX5 1.6 05 Volvo V70
L. Ron Cupboard
75 Landrover lightweight,88 BMW535i
Looks nice, I was watching this one too, the people you bought off sell a lot of classic 900s and seem to know their stuff. Could be a bargain!!
75nut
Well picked it up today and all seems good so far! Massive servie history and 100% complete mostly Saab or specalists. It pulls well , all electrics work,and has an excellent body bar some small bubles on one rear arch and on bonnet corner. Other than that two bit need welding on bottom of doors to tidy up some rot. Headlining in sagging and bit of a mess so will attempt a tidy up. But with 12 months ticket and driving so well may just run it as it is!
75nut
Oh the seats are in excellent condition! Will giv eit a TCut and clean and repost some pics
75nut
Jan 10, 2011 12:12:23 GMT
Last Edit: Jun 22, 2011 19:38:15 GMT by 75nut
75nut
Jan 19, 2011 14:47:24 GMT
Did the rear passenger arh repair over last couple of days, had to cut out complete setion to get to good metal and also cut out a section of wheel well that also fell out when I discovered the fibreglass bodge repair. I made up the sections using a hammer and dolly set to fold a return lip between arch and innner arch, and coated everything in weld thru high zinc. In the wheel well used seam sealer after then coated with more zinc, then normal primer then black paint, and then waxoyl. On the out wheel arch I have leaded the repair in ready for filler and sanding (prob get done one of the evenings or weekend. Looks like Ill be repair front wing as cant find one. THen its bottom of the doors and the metal should be done bar any nasty suprises. The bonnet is ready to fit as paint hardened for cutting in, along with wing mirrors. Pic of arch in lead -
Last Edit: Jun 22, 2011 19:39:35 GMT by 75nut
75nut
Jan 19, 2011 21:38:28 GMT
Last Edit: Jun 22, 2011 19:40:54 GMT by 75nut
L. Ron Cupboard
Jan 26, 2011 11:04:24 GMT
Really enjoyed watching your progress on this, it's nice to see work done with care and attention. It never ceases to amaze me how few good repro panels there are about for these excellent cars. Keep up the good work.
75nut
Jan 27, 2011 11:08:56 GMT
Thanks Count, work slowed things down this week, but have broken the back of the front wing now , lead loaded, just got a bit of shaping to do and a skim of filler. Need a warm weekend to paint the top coat now , has to be done outside as garage full but got a pop up gazebo to help do a better job. Just will ad plenty of paint then plenty to cut back. Then its the bottom of the doors and metal work finished. Then headlining.
It has a cracked manifold from the block to the turbo, don't spose anyone know s of best place to get a good used one or a repair that works?
75nut
Jan 27, 2011 11:10:34 GMT
BTW this is what the front wing looked like when I cut out the rot
Last Edit: Jun 22, 2011 19:41:30 GMT by 75nut
g40jon
Jan 27, 2011 16:05:39 GMT
nive to see someone repairing panels rather than just swapping them for new! it'll be one cool car once its done. they seem pretty thin on the ground these days
75nut
Jan 27, 2011 21:42:48 GMT
Cheers G40, the rear atch was proper solid apart from a small section so figures I go for it without a new panel. To be honest could of done with a new wing Ive put alot of metal in. I always liked the old 900 so when this popped up just down the road I had to have a bid!
75nut
Jan 30, 2011 22:17:53 GMT
Cracked on with the front wing this weekend. Fab'd repair sections for font arch and inner arch, zinc etch primed, filler primed and normal prime, then flated with 240,400,600,800 and used the matched rattle cans I got (had rubbish nozzles on them that really made it splatter so loaded the paint and will cut back with 1200 grit after a week to harden). Got the fresh painted wing mirrors on and painte dup the replacement petrol cap for my flappy one (it was grey) The rusty and flaking front headlamp wipers where bothering me so took em off , sanded down and sprayed with some enamel black Fitted some kit back onto the rear wing paint thats hardend for a week , still to flat ti back yet. plan is let the front wing harded then mop and polish the whole car after flatting the painted sections.
Last Edit: Jun 22, 2011 19:42:58 GMT by 75nut
L. Ron Cupboard
Jan 30, 2011 23:25:43 GMT
Regarding your cracked manifold get yourself a couple of cast iron rods for an arc welder, grind out the crack, heat up the casting and have a go at welding it. As long as you heat the casting you can get quite a durable weld, rods are quite expensive but cheaper than a new manifold. Hope it helps.
75nut
Jan 30, 2011 23:29:27 GMT
Cheers Count! don't have an Arc tho only a gassless MIG
75nut
Nipped home for extended lunch and got my father i law to help me put the bonnet back on and gave her a quick wash to get the filler dust mud etc off. Still need to fit some of the kit back on, and flat the paint. THen going to mop the whoe car a refresh the plastics, but she is coming back together on the outside slowly.
75nut
Last Edit: Jun 22, 2011 19:43:59 GMT by 75nut
75nut
So she is now rot free on the arches and bonnnet and looking very pretty, but first trip out to work today and she cut out while idling on the drive, an then while driving as soon as I tryed to accelerate she spultered and bunny hopped, so had to continue journey under very light pedal pressure. Seem to improve, but wondering if it may happen again when I head back.
I did jet was the engine bay when I tidied it, but kept the engine running and avoided the fuse box etc. But do you guys think it could stil be a firing issue with a wet distributer, or is it more likely a fueling issue, dirty filter etc?
curse word with mechanics so any guidance on what to check first would be greatly helped (and its location in the engine bay lol!)
Cheers!
what management system do they run?
75nut
Feb 10, 2011 12:15:14 GMT
Running fine again now! Must have got a bit of water in the cap when pressure washing, dried it all out and wd40'd all ok now.
