I have this left over from when i had an avenger.
Essentially it is a Sunbeam/Avenger axle case and halfshafts fitted with a plate type LSD as supplied by Mal Staurt motorsport. The CWP is a custom made 4.1:1 ratio, also supplied by Mal Staurt. The case is fitted with an alloy axle brace and has done only a few miles on a Avenger circuit racer after a full rebuld with all new bearings. The case also has a pair of polybushes fitted in the two cental mounting holes.
Due to the value of the custom CWP I'm asking £650ono for the whole unit. I don't wish to split at this time but may be forced to if i cant sell it as a whole so it might be worth registering your interest.
I also have a avalible a number of other parts avalible including
1600 head in need of recon
1 set of 1600 rods/pistons
several oil pumps
clutches
rockers
3 spare 'TI' pistons
gasket kits
new simplex timing chain and tensioner
and plenty of other assorted engine bits!
also
a pair of roller top strut mounts in good condition (£45 the pair)
a pair of new old stock front TCAs for sunbeam/late avanger (£50 the pair)
a pair of 'used but good' front TCAs (£20 the pair)
a set of brake pads for standard avenger (£5)
Everything is located in Sudbury, Suffolk. If you are serious please PM or email me at slaterspeed@gmail.com as I'm pretty bad at checking my forsale threads!
several oil pumps
clutches
rockers
gasket kits
also
