had these sat in my garage for quite some time now, with the intention of one day doing something with them.
alas i've tripped over them one too many times so i want rid ;D
the pinto is from my 2.0s capri, it's a non 205 block, comes with head/sump/manifold/carb maybe. it's been sat for 5 or so years but in a garage so will still be useable. £50.
crossflow, taken out of my mk2 escort before the zetec conversion. same condition as the pinto, also comes with the same parts, you can basically have whatever i find for it, so maybe an alternator/starter etc. it's a 1.3 ghia engine, so slightly bigger ports/valves. 711m block, i can find the T number for you if you want before travelling. £50
zetec, 1.8, doesn't work, doesn't come with any ancilleries, no rocker cover, no sump, water pump, i used it as a dummy engine when i was fitting my zetec into my escort, and also to pillage it for a few bits. FREE.
all located in NP13
all located in NP13
