Jan 25, 2011 23:39:26 GMT
I reckon it's home-made: VW surely wouldn't leave the detents in the doors where the door handles were and 'factory' hatchback/estate to van conversions usually just have pre-cut inserts to block out the windows. Does it have a bulkhead behind the front seats?
Copey
thats home made, as above, door handle dents, plus a van version wouldnt have doors, just be a pannel van, def home made
Home-made. Factory vans wouldn't have the door gap at the back - and it looks as though the rear windows are just painted white to me.
I'll add to the home made opinion on this one. I'd expect VW to do things differently and not bother fitting rear doors, let alone leave the handle dents in. The white of the windows looks different to the white of the car which hints at a repaint. However, if the car's solid it could prove a good base to finish off the job properly.
It is easy to say VW would not fit the rear doors on a van version -but the tooling required to build a 3 door estate shell would cost well beyond the demand for a golf van. I have seen 5-door factory vans before. You would need to go and see this one to be certain.
1986 Panda 4x4. 1990 Metro Sport. 1999 Ford Escort estate.
Lawsy
I would say 99% certain its home brewed, VW never produced the Mk3 golf as a van of that size - the Mk3 golf van was based on the 3dr hatch only - same as the Mk1 and mk2 golfs
the larger van at that time was the caddy, polo fronted...
and to add to above, if leaving doors to open from inside, why remove the external handles and has only had the wiper removed by unbolting, shoudl take the mech out and blank off
could be cool to do like elpassat's van tho, weld up rear doors and do it properly
Jan 26, 2011 10:57:51 GMT
I wondered if it maybe originated in the Republic, I know that they had loads of 'vans' that were delivered ready to be converted to cars by the end user to keep the tax down. You just needed windows, seats and door cards.
My mate had an awful (for other reasons) Renault 19 that started life that way.
hamps
www.medwayrscentre.co.uk
Jan 26, 2011 11:42:21 GMT
The skoda felica van was a 5 door, if its very cheap its worth a punt, might be a little rare-bit
Jan 26, 2011 12:10:55 GMT
This is what a genuine Mk3 Golf van looks like: Having said that, if it's cheap, buy it!
1967 Morris Traveller 1971 Series IIA Land Rover 1991 Golf GL 4+e 1992 Corrado G60 1986 E28 BMW 528i
Garry
East Midlands
Jan 26, 2011 12:54:31 GMT
dungbug
'Ooligan!
Jan 26, 2011 13:31:18 GMT
I would say 99% certain its home brewed, VW never produced the Mk3 golf as a van of that size - the Mk3 golf van was based on the 3dr hatch only - same as the Mk1 and mk2 golfs the larger van at that time was the caddy, polo fronted.. That's what I thought, never seen a '4 door' Golf van. Looks like a home brew to me.
Past: 13 VW Beetles from 1967 - 1974 Bay Window Campers (1973 & 1974) Mini's (1992 Cooper lookalike & 1984 '25 Anniversary) MK2 Polo Coupe S (1984 & 1986) MK2 Polo Breadvan (1981 & 1984) MK4 Escort (1989) MK2 Granada Based Hearse (seriously) Fiat Uno 60S (1986) Punto 60S (1998) Cinq (1997) 1998 Yamaha YZF600R Thundercat 2003 Ford KA
Current: 2004 Ford Focus (barely alive)
hodaz
I wear this hat so they think I am one
Jan 26, 2011 15:41:11 GMT
I also saw that on Auto Trader and was tempted to have a look, but I'd be scared about where it sat with insurance with it being a car turned into a van, I can see that being a can of worm I wouldn't want to open.
Jan 26, 2011 15:50:15 GMT
comes up as a golf CL TDI car derived van if you run the reg, maybe its a special order vehicle from VW.
bortaf
Jan 26, 2011 16:42:58 GMT
Factory made possably some countrys gave huge tax breaks on comercial vehicals, sweden is one where you could get a sierra van made out an estate with no back seats, perhap it was the same in Ireland? here have a taunus van brochure Land rover used to sell discovery vans as well, you got the rear seat as a factory "extra" and converted back to a car after it was registerd and you'd saved on the new vehical tax ;D
Last Edit: Jan 26, 2011 16:52:49 GMT by bortaf
R.I.P photobucket
bortaf
Jan 26, 2011 17:00:15 GMT
R.I.P photobucket
