Jan 31, 2011 20:45:41 GMT
Steve
Jan 31, 2011 20:47:44 GMT
Threaded bar will work chap If you can obtain some in High Tensile then go with that, cut a section out of the panhard rod and weld a couple of nuts in.....simples ;D Edit - Beaten by Seth, or just put the adjustable part at one end
Last Edit: Jan 31, 2011 20:49:48 GMT by Steve
Club RR Member Number: 160
Adjustable panhard rod.. How?Rich
@foxmcintyre
Club Retro Rides Member 160
Jan 31, 2011 20:51:59 GMT
Cheers Seth, but seems pricey (for a.. ahem.. bodger) and I don't need rose joints for boating about Asda car park, seems far too showy! ;D Threaded bar will work chap If you can obtain some in High Tensile then go with that, cut a section out of the panhard rod and weld a couple of nuts in.....simples ;D Yea, looks like the way to go. Wouldn't want to use anything not high tensile to be fair, which is why a trackrod popped to mind to be honest. Have loads of old ones with dead inner ball joints at work..
@foxmcintyre
Jan 31, 2011 21:28:33 GMT
Seems easy enough, innit? Just looks like the rose joint parts won't give enough adjustment over time, as I need to adjust it now to compensate for spring 'wear', and at a later date when I go lower/stiffer, and don't want to have to remake it at that point.. Hmmm..
Jan 31, 2011 21:36:57 GMT
No engine too large,no car too small,,,,,
Jan 31, 2011 21:37:18 GMT
just make it adjustable at one end, cut off the end, weld in a tube we will conveniently thread, put in some threaded bar and et voila obviously its slightly more complicated but not by much
@foxmcintyre
Jan 31, 2011 21:42:05 GMT
That, my man, is exactly what I orignially had in mind!! Have a bonus Cedric point!
ChrisT
Club RR Member Number: 225
Adjustable panhard rod.. How?ChrisT
@christ
Club Retro Rides Member 225
Jan 31, 2011 21:42:42 GMT
rose joint both ends, one threaded the other way - makes it easier to adjust and quite a bit of travel. What sort of size is the rod you need? I've got an adjustable one I had made up years ago going spare as I just chopped my std one down instead.
@foxmcintyre
Jan 31, 2011 21:51:10 GMT
rose joint both ends, one threaded the other way - makes it easier to adjust and quite a bit of travel. What sort of size is the rod you need? I've got an adjustable one I had made up years ago going spare as I just chopped my std one down instead. I'll measure and take photos tomorrow, easiest way to describe it I think.
kee
Jan 31, 2011 22:00:21 GMT
Use one of those in-situ adjusters, all the fiesta boys use them instead of replacing tyres and arches all the time ;D
The Doctor
Club RR Member Number: 48
Jan 31, 2011 22:48:33 GMT
if you make one, just make it adjustable when in place. I've got an (expensive..) Whiteline panhard rod on my daily and you have to remove it to adjust. Which is a curse word to do.
