mirafioriman
My next project.......
Set of four 14" 131 steel wheels. Blasted and powdercoated by their previous owner. Not perfect but in good condition. Worst bit is that one rim edge has been damaged and beaten back into shape at some time (see photo) £100 for the four.
mirafioriman
Feb 16, 2011 19:33:26 GMT
Price drop bump! Will take £60 for the four.
Feb 16, 2011 21:40:51 GMT
whats the width?
mirafioriman
Feb 16, 2011 21:53:29 GMT
5.5J X 14 in size.
Feb 16, 2011 22:35:30 GMT
Do you know if they would fit a panda, or will i need different nuts (oo er )
mirafioriman
Feb 16, 2011 22:40:23 GMT
If your panda has steel wheels already then the nuts should be fine. I know they have been fitted to X19s and Unos if that helps.
Feb 16, 2011 23:02:15 GMT
You might have to chop the wheel bolts down on the rear. I did when I fitted the 13" versions I bought from you as standard length they hit the rear brake mechanism. Infact i've probably still got the bolts in the garage if you want them PS.
Matt
