Feb 22, 2011 12:55:58 GMT
I've got some tasty Wellers for my Bond, but I've ran into a bit of a problem: the stud holes in the wheels are slightly too small to go over my M12 studs. The wheels were probably made with 7/16in studs in mind. The holes need enlarging by a very small amount - no more than 2mm.
What's the best way to do this? And am I going to encounter any problems? The seats are regular 60deg taper affairs, and the wheelnuts I have are just ordinary Ford steel wheel nuts.
Feb 22, 2011 13:06:19 GMT
I'd just do em with a hand drill, but a vertical miller or a big pillar drill would be better.
Matt
Feb 22, 2011 13:59:34 GMT
a tapered drill bit would be best inho , pretty self centreing even with a cordlesss etc
yes ,it started badly ,petered off in the middle and the least said about the end the better!!!
Feb 22, 2011 14:14:25 GMT
Good call on the tapered drill bit! I don't have a pillar drill apart from one that you put an electric drill into and I wouldn't get the wheel under! I'll get a tapered bit and go slowly by hand - seems like the best plan. I just didn't want to mess it up!
scruff
Feb 22, 2011 17:06:40 GMT
Get a stepped drill.
A normal drill will leave your with triangular holes and a tapered drill will leave tapered holes.
It won't be very happy cutting lots of steel so coolant/lubricant will be required and I'd probably expect it to chew a couple of them doing lots of holes.
Best would be drill to 11.8 then ream out to 12 but you really need a mill or radial arm drill to do that.
Can you not get a local engineering firm to do it one lunch time? Can't see it taking them more than 30 mins...
Last Edit: Feb 22, 2011 17:07:50 GMT by scruff
I spy a trend...
scruff
Feb 22, 2011 17:08:45 GMT
Step drill - but get a metric one!
Last Edit: Feb 22, 2011 17:09:22 GMT by scruff
I spy a trend...
Feb 22, 2011 17:13:34 GMT
Step drill from behind (so you don't curse word up the 60 degree seat)
You'll find it hard to get a normal drill through from in front without it rattling about and making triangular holes on at least a few of them.
Halfords do the step drills if you are desperate.
Feb 22, 2011 17:20:45 GMT
Thanks for all the advice. The wheels have the 60deg seats welded in it looks like, so the bit that I'm taking out is quite thin, at the edge of the taper. Good call on drilling them from behind too! I'll use a cordless drill as it's slower, and use plenty of oil. Luckily the front wheels are fine (Dunlop make) so I only have 8 holes to do!
Last Edit: Feb 22, 2011 17:21:20 GMT by BenzBoy
Feb 22, 2011 17:27:11 GMT
Sorry to hear this Dean. Didn't think about nut size did we! Worth persevering, and I look forward to seeing the trial fitment shots.
Feb 22, 2011 17:37:39 GMT
Sorry to hear this Dean. Didn't think about nut size did we! Worth persevering, and I look forward to seeing the trial fitment shots. No problem at all mate, going "off the beaten track" a bit with wheels always brings up a few issues.
Feb 22, 2011 18:47:07 GMT
bring 'em here and use my pillar drill
Feb 22, 2011 18:57:10 GMT
bring 'em here and use my pillar drill Now that sounds like a plan! Thanks mate.
Feb 22, 2011 18:58:46 GMT
I still owe ya for heater fitting efforts
