Feb 22, 2011 23:27:37 GMT
Does anyone know if mini seat belts will fit a morris minor? It's never had seat belts fitted before, and thought second hand mini ones might be a budget option compared to buying a brand new kit. I can't really see why not, but looking on the MMOC site, they only seem to talk about fitting the special kits which are out of my budget at the mo!
Anybody done any budget seatbelt installations?
If at first you don't succeed........ ....Don't try skydiving!
Have a look on the Securon web site - www.securon.co.uk/You will see the stalks on a Mini aren't long enough. When I fitted seatbelts to my 2 door Minor I tried a couple of sets from my "spares" box but they weren't suitable so ended up buying a new pair. If you look at the application guide then you might be able to find other cars with the right belts. Paul H
Feb 23, 2011 11:20:23 GMT
Cheers, I'd been on the securon webesite already, but not looked hard enough to get the required info. Does seem the stalks will be 15cm too short, which I guess is quite a lot. There's nothing very common with the same set up. Looks like I may have to open my wallet a bit wider....
Feb 23, 2011 12:40:48 GMT
Not ever played in a Morris (come to think of it, never even sat in one!) But is there the space to simply extend the mounting point, with a bit of 8mm steel?
Hole in one end, bolt down to original point, and captive nut welded to the other end, and mount the mini stalk to that
not exactly pretty, and factory-looking, but as long as your mounting point's strong enough, it should be fine (unless I've missed something rather obvious?)
Feb 23, 2011 13:09:16 GMT
not exactly the same, but i used static 3 point mini rear belts in the front of my 4 door A35..... they're so cheap new off somewhere like ebay, i really wouldnt consider using second hand belts unless you know the history of them.......
Current fleet: '58 A35 (half mine) '67 11 window splitscreen vw (half mine) '77 mini 1000 (not quite 1000 any more!!) '86 Armstrong MT500 '89 XR4X4 '94 Corrado VR6 Some sort of sevenesque kit car (no age yet!!) '01 Mondeo estate 2.0 (engine eventually destined for kit car!) - scrapped, engine only left! '98 E300 estate, rusty but seemingly reliable, fast-ish tat hauler. eventual engine donor A35 van, or whats left of it after it lived in a field for many years
Feb 23, 2011 21:59:28 GMT
I'd not feck about i'd just get the ones that fit it. Morris Minor centre sell them as do Bull Motif and loads of other places. They are probably just the Securon ones anyway
