Time has come to part with my 406 estate I'm selling as spares or repair as there is only half a months MOT on it and a couple of jobs will need doing.
1: slight leak from the in tank fuel pump (looks like the seal needs replacing
2: Knock on the front offs side suspension,can't see what it is only does it as you go on and off the throttle so could be worn engine mount but not sure.
3: Needs front discs and pads (new discs and pads supplied.
It had new rear discs and pads plus hand brake shoes 6 months ago, new clutch 3 years ago with solid flywheel.
Mileage is 146000 but still does 60mpg on a run.
One front fog light is misted up and no longer works
Air bag warning light flashes (piece of black tape fixed that)
Excellent load lugger/parts chaser rough around the edges but drive spot on.
£300 ono
More pics soon.
£300 ono
More pics soon.
