BMW 325i 1987 E Reg M Tech 1 sport manual presented in Lach Silver
A rare opportunity to purchase an E30 325i sport one which has not been messed around with!
Car is completely original down to the Dealer supplied number plates!
Spec of the car is as follows as it was when it left the factory.
Full M tech 1 body kit, shadow line trim, Pop out rear windows, M tech ride height, Bilstein Suspension, Limited Slip Diff, Sports manual gearbox, Heated washer jets, Battery in boot kit, Map light mirror, Premium Tweeter pods, M tech 1 steering, Original One piece leather gearnob, Black roof lining, Electric aerial, Electric windows, electric sunroof, sports houndstooth interior with rear headrests, 15" BBS alloys, power steering and so on.
The interior of the car can only be described as in very good condition. The front seats work just as they should and have no loose mechanisms. There is no wear and the bolsters are nice and firm and really hold you in place. Rear seats are also wear free and have no rips or tears Arm rest works as it should. Gearnob has some wear which is to be expected over the years but is still presentable. Carpet is very clean and is pretty fresh with no damp smell. The map light mirror works as do the electric windows and sunroof. All the dials, stalks and switches work. Has a very nice Period Pioneer tape fitted along with period speakers, the original BMW tweeter pods also work and all sounds fantastic.
The engine bay is nice and Original. Has not been tinkered with dodgy aftermarket add on's. Boot area is the same again no big speaker holes or amp fittings!
Mechanically the car cannot be faulted has plenty of poke and drives nice and tight with no funny noises. There are no overheating issues. Suspension is nice and firm, exhaust sounds just as it should and the lsd has no whines.
The exterior of the car is pretty straight is has had some welding to the rear battery tray and D/S jacking point but has all been done to a good standard. There some marks here and there but this is to be expected for a car which is 24yrs old. Worst being a tiny bit of bubbling on the p/s rear arch lip (Has not gone through just needs cleaning and painting). The usual areas other wise are very good, sunroof panel, sunroof drains, scuttle, floor pan, Jacking points, sills look pretty good from what I can see, and the panels are straight. The end cap on the rear bumper needs fitting correctly as it sitting slightly bent.
For the MOT the car has had a full service including, Oil change, filter change, air filter change, Spark plugs, rear drop links, rear discs and pads, brake shoes, axle bushes, front grooved brake discs, pads, drop links, complete track control arms, Wishbones with eccentric Bushes, recently had 4 new tyres fitted
Alloy wheels are in good condition and complete with centre caps.
The full original BMW toolkit is present, jack, wheel brace, wheel chock and centre cap removal tool.
Has the original Spare wheel with almost new tyre. The glove box torch is present and shockingly still works. The owners pack is all there. Unfortunately the service book is blank but I am certain the car has been maintained as it drives very well. There are several previous MOT certificates which back up the mileage along with several invoices.
Mileage is 149,000 and has just under 12 months MOT
There you have it I have describes the car How it is you are more than welcome to come and view it.
Can provide more pictures if wanted.
Price is £2795
Car is located in Birmingham 10 mins from the Birmingham airport and the NEC.
Price is £2795
