hi all
i have here some slots that are triumph fit 95.25 that i want to put to fiat 98. how would i do this they are too close for redrilling (i think) could i open the holes up slightly and use wobble bolts to take up the rest (ovaling the wholes slightly- is it safe). am i wasting time here i really want som slots in fiat fitment but ive only ever seen a couple of sets none for sale though
cheers
rob
it's not the holes that are rotten it's the metal around them
1975 trabant 601s deluxe
1987 trabant 601 Kombi
1996 fiat cinquecento 1.4 16v
If they're steels I wouldn't hesitate a second to widen the holes.
Woops, must read post at least twice ;D If they are slots there should be loads of room for a second set of holes, or if they are the kind which needs sleeve nuts almost all yank fitment ones have long holes to give double pcd's
Last Edit: Aug 6, 2011 22:05:51 GMT by dude
or you can have them welded/filled. then new holes drilled
If they're steels I wouldn't hesitate a second to widen the holes.Woops, must read post at least twice ;D If they are slots there should be loads of room for a second set of holes, or if they are the kind which needs sleeve nuts almost all yank fitment ones have long holes to give double pcd's Exactley how I did mine, I went from 4x3.75 too 4x100 using inserts so I can use nuts instead of sleeve nuts.
muttley racing ftmfwmf
What 98pcd rims are you after?
What 98pcd rims are you after? I really want som slots in fiat fitment but ive only ever seen a couple of sets none for sale though ![;)](//storage.proboards.com/forum/images/smiley/wink.png) Edit: Or if you mean what 98? as in 4x98 or 5x98 then I'd imagine it's 4x98 seeing as he's trying to get Triumph slots to fit.
kevfromwales
if you buy wolfrace slots, they have solid centres, so enough room to drill another set of holes
- ford fitment (4x108) re all over ebay in 13x5.5j - and even if you want wider ones they do turn up
kfw
