I've decided to sell my corsa sport as I can't afford to run two cars anymore.
I bought it back in september as a bit of a project, it was a non runner needing a head gasket.
Its had in the last 2000 miles:
- Head gasket and valve stem seals
- Bottom ball joint
- New rear brake shoes, wheel cylinders and both handbrake cables.
- Cambelt, rollers and tensioners.
- Brand new radiator and switch,
- Spark plugs
- Waterpump and thermostat
- Replacement Air Flow Meter
- ICV removed and cleaned
The interior has got cav gsi steering wheel, NOT the mountenay wheel pictured, late spec sport door cards, rear seats/ seatbelts removed and two cavalier turbo seats fitted.
Exterior: Standard sport with Lenso alloys with 4 good 195/45/15 alloys.
Chassis: 2.0 16v brakes, EBC discs, greenstuff pads, brand new SPAX RSX coilovers fitted 1200 miles ago. Motorsport driveshafts with big block cvs and hubs, all new cv boots.
Engine: 20XE with good F20cr box all works fine, colour coded rocker cover.
110,000 miles on the shell.
MOT to April 2012, Taxed till september 2011.
Car is in maidstone, kent, close to M20, Junction 7
I don't have internet access so please NO PM's
Contact steve on 07912 845261
Also got a spare set of pads to go with and a set of camber bolts.
One outer cv joint will need replacing as its just started to grumble a bit.
£1350 or very near offer.
- Bottom ball joint
- Spark plugs
