judgie
wanaba stig
transit mk3 2ltr pinto with a mt75 gearbox is whats in the van at the moment and i want to fit a 2.9 v6. looking round the www. theres a lot of conflicting info about weather it will bolt up or not. any one know if it will or what parts i need to do this swap? cheers rob
2.9v6 into transitDez
@dez
Club Retro Rides Member 34
the gearbox bolt pattern is different, if thats what you mean? all I4s are one bolt pattern, all v6s are a different one.
to keep your current prop, etc. youll need to find a mt75 for a v6 application (which are rare, I'm pretty sure they were never a uk option or something), or make a hybrid box using a xr4x4 box with the transfer box replaced by 2wd bits- i know its do-able, but I'm not entirely sure how as ive never done it.
otherwise, youre looking at going type9 and having to change the prop and gearbox mount too.
the rest is all pretty straightforward.
judgie
wanaba stig
Transit mt75 is different to the car one. There's a adopter plate to bolt the engine to the box which I'm hoping to mod to fit the v6
bortaf
It's mainly ambulances that were 2.9, keep an eye out for one it will have all you need, like engine mounts and adapter but as you'll need a V6 box you might find it easyer nd cheaper to buy a compleat amby ? Ive heard of peeps moding the pinto plate for a V6 but you still need the V6 box
R.I.P photobucket
judgie
wanaba stig
What's the difference with v6 box?
Ads 19
My old r19
Aug 20, 2011 22:27:14 GMT
is auto a problem, most ambulances are. have a mk3 auto here atm, and its for breaking, been hoping to use in a small mk3 but can't find good early one anywhere
Aug 21, 2011 10:06:37 GMT
Transit gearbox has the gear stick coming out the side/top, a car box will put the stick and 18" to far back i would say, theres loads of room in a transit engine bay, mounts can be fabbed pretty easy, auto gearbox would make life much easier, but the 2.9 is only 150bhp, in a transit with an auto on it it wont feel fast.
If your happy with an auto box then a 24v is a better bet, will still fit the length of the engine bay better than a V8 and has 200bhp so will feel brisk even with the stock auto on it. I'd be looking at a higher geared axle as well.
stueyt
Saving cars from the scrapyard.
Aug 21, 2011 10:29:08 GMT
Why can't you just change the bell housing over, wouldn't that make things a lot easier? I don't know if you can, but it's a thought as I have never done this either, but surely the bell housing just bolt on using 4(?) bolts.
Cheers,
Stu.
Always looking for the next project!
mk2cossie
Club RR Member Number: 77
2.9v6 into transitmk2cossie
@mk2cossie
Club Retro Rides Member 77
Aug 21, 2011 10:34:15 GMT
mt75 boxes don't have removeable bellhousings, its part of the gearbox front casing the 24v will fit, but needs the bulkhead 'adjusting' to clear the monstrous alloy heads when fitted in the transit you may be lucky and find the gearbox in the transit has an adapter bolted to it already, as some of the diesel engined ones were like that. if thats the case, just redrill the plate to bolt to the cologne engine
IDY
Aug 21, 2011 10:39:09 GMT
Why can't you just change the bell housing over, wouldn't that make things a lot easier? I don't know if you can, but it's a thought as I have never done this either Unfortunately the MT75 bell housing and the gear box casing is a one piece casting edit - too slow typing again
Last Edit: Aug 21, 2011 10:40:11 GMT by IDY
I will get round to finishing it at some point
stueyt
Aug 21, 2011 17:44:18 GMT
Ok guys I stand corrected, I was thinking of a different 'box then :s
Cheers,
Stu.
Aug 21, 2011 18:39:31 GMT
The LT77, or the R380 spring to mind Stu I don't think either were ever fitted to the ford V6 though? Shame, as they're quite nice 'boxes
