stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Aug 10, 2011 13:25:59 GMT
Wotcha folks, who knows about fraud 2.8's then?
Ive got an ex sierra 4x4 2.8 lump. 4x4 sump removed and a 2wd sump fitted. I also fitted a granada 2.8 carb inlet manifold. When i filled the damn thing with coolant it somehow found its way into number 4 cyl. I assume my manifold is not compatible with the injection heads inlet ports, which is odd as it looks very similar underneath to the removed injection fanni-mold.
Anyone know whats going on? Or what i actually need to do the job?
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
Aug 10, 2011 13:37:22 GMT
It should fit... I've put carb manifolds onto ex-injection 2.8s plenty of times (mainly for autofive!) and apart from one bolt being too short (and a pain to find) it goes straight on. Maybe your gasket shifted, or there is a small piece of debris trapped between the heads and the manifold?
bortaf
Aug 10, 2011 14:03:05 GMT
Same a Mr scarey, done it untold times, the only time i've had this problem was when the heads were skimmed and the inlet wasnt
R.I.P photobucket
Cologne inlet questionHARDCORE
@hardcore
Club Retro Rides Member 190
Aug 10, 2011 16:13:17 GMT
Racers put carb inlet manifolds on injection 2.8's routinely - 'tis the rules as I understand it..
Aug 10, 2011 18:26:13 GMT
did you use a cheapo inlet gasket? are you sure you bought a post-1977 inlet gasket?
Someone just shot the elephant in the room.
mk2cossie
Club RR Member Number: 77
Cologne inlet questionmk2cossie
@mk2cossie
Club Retro Rides Member 77
Aug 10, 2011 20:36:12 GMT
as said, it should all be like lego to swap bits about ;D not a 2.9 lump you have is it? how many exhaust ports has the engine got?
bortaf
Aug 10, 2011 21:05:58 GMT
did you use a cheapo inlet gasket? are you sure you bought a post-1977 inlet gasket? good point the heads and inlets changed in 77
R.I.P photobucket
stinkwheel
Aug 11, 2011 15:08:13 GMT
Hi Folks, Thanks for all he replies, Yep its deffo a siamesed port 2.8 and not a 2.9 (unfortunately) First inlet gasket was good quality, the second not, but they both leaked the same And yeah, post 77 gasket too Weird innit................
stueyt
Saving cars from the scrapyard.
Aug 11, 2011 15:31:12 GMT
Did you put any sealent on the gasket or just put it on dry? Did you put the gasket the right way round and up the right way? Not teaching you to suck eggs but it is easy done, even twice Cheers, Stu.
Always looking for the next project!
stinkwheel
hmmmm, i thought so, but now I'm not sure, report back later when ive looked
stinkwheel
Sept 5, 2011 13:50:57 GMT
UPDATE...................... (for anyone who actually cares) It was not the inlet, see where was getting confused was this, i didnt expect the head gasket on the L/H bank to have a HUGE hole in it. So wit the head gaskets changed and another new inlet gasket, ta da. Watertight. Then i fired it up and the waterpump bearing screams merrily to itself, but thats another story Thanks all for the input.
bortaf
Sept 5, 2011 18:10:33 GMT
glad it's sorted ;D it deffo allways helps if the OP lets us know what it was in the end
R.I.P photobucket
