SUZUKI VITARA 2.0 V6
MOT TILL OCT 27TH
SORT TAX
SUSPENSION LIFT 1.5 INCH
31 ICH SAHARA MUD TYERS ON 15INCH ALLOYS
wheel spacers
RUNS OK
for sale my vitara v6 offroader was a daily driver untill recentley when i decided 2 make it into a green lane/ off roader she still has a mot till dec both sills have holes in them we lifted it 1.5 inch but wasent enought 2 fit 31 inch tyres so we cut the arches out with a angle grinder , the fronts look ok but the rears don't look good as we had 2 bash the lip up with a hammer while we were off roading because of rubbing the tyres body kit has been tacken off passanger window dosent work, timing chain is noisey speedo dosent work has 30mm wheel spacers fitied
this isent a ideal motor 2 buy if you want 2 use it on the road but is an ideal off roader
also the front diff casing has a hole in it were we hit a rock while offroading her last this will need this replacing can be driven in rwd only at the moment
located in wallington south east london looking for 400
pm or call 07982194058
will post pic tomorow
MOT TILL OCT 27TH
SORT TAX
wheel spacers
RUNS OK
