Aug 20, 2011 22:46:15 GMT
Anyone ever seen or heard of anyone using an air con compressor to power air suspension? Its something I'm considering for my W115, there are a few things drawing me towards it; 1. I already have the compressor so wont have to spend any money. 2. I don't have to fill my boot with compressor 3. I can drive it straight off the engine, engage and disengage via pressure switch to compressor electromagnetic clutch. The concerns I have are firstly whether or not the compressor will be up to the job and secondly how to keep it lubricated. Any thoughts appreciated.
1992 190E 2.0 - first car, currently being driven by the wife.
1989 500SEC
1968 W115 4.2 V8
2000 CL500
Ads 19
My old r19
Aug 20, 2011 23:43:49 GMT
isn't the lubricant in an aircon gas. i've used little air compressors from 5Ol compressors. need about .5hp-1. and easy to adapt to a belt off the engine. this was on a perkins 4203. truck tank to use as resevoir and a excess pressure valve. sure you wont notice much performance drop. my use was brakes on trailer and air horns
Aug 21, 2011 13:45:58 GMT
Aug 21, 2011 14:04:04 GMT
You need to use an aircon compressor that has built in lubrication reservoir instead of the common type which used the air con fluid as a lubricant. The type normally used is called a York unit. They can be found on US vehicles and some older Volvo's.
Paul H
Aug 21, 2011 18:37:35 GMT
Also, they supply PRESSURE, not VOLUME per-se
If you want your car to be hopping up and down (or even have movement measured by a watch, not a calendar), and old air-con compressor is NOT the way forward. By far, the easiest option, would be to use an old pub-sized CO2 cylinder, and fill it up using a compressor at home
mat91
Aug 21, 2011 20:25:56 GMT
The stupid is everywhere
Aug 21, 2011 20:59:51 GMT
Also, they supply PRESSURE, not VOLUME per-se If you want your car to be hopping up and down (or even have movement measured by a watch, not a calendar), and old air-con compressor is NOT the way forward. By far, the easiest option, would be to use an old pub-sized CO2 cylinder, and fill it up using a compressor at home They are nowhere near big enough, you'll only lift a car two or three times with a pub gas sized bottle full to 150psi.
Aug 21, 2011 21:30:57 GMT
twice, is better than not at all
get the electric setup from the uzz31 v8 soarer, its in the fornt drivers side wheel arch. its quite small, about the size of a large mug.
brc76
Aug 23, 2011 11:43:15 GMT
It's pretty common in the USA to use the old AC system to run the airride, but as mentioned before they need to be the compressors with the self oiling system rather than the ones that use the gas to lubricate.
bortaf
Aug 23, 2011 14:46:48 GMT
You can use any pump you want as long as it's fit for the job, i ran my LDV ambulance for months on a cheapo 12V tyre inflator form halfords but the speed and the amount of time you raise and lower will depend on the size of tank you use to hold the air, most normal air susspension pumps are really quite small cos they deliver pressure not so much volume, the volume is dictated but the tank, forget pub cylinders! if you use it all then you drive home on the bump stops unless your using it as a reseve filled by a pump in which case you may as well get the propper tank with all the blowoff safty valves ect from a lorry/ambulance ect
R.I.P photobucket
Aug 23, 2011 20:38:11 GMT
What about putting an in-line oiler on the suction side of the pump and an oil trap on the pressure side, maybe even hook it up so the oil trap drains into the oiler on the suction side?
I just want to be able to raise and lower 4"-6" or so in a couple of seconds so I can get over speed bumps etc.
1989 500SEC
1968 W115 4.2 V8
2000 CL500
Tim
Aug 23, 2011 21:35:20 GMT
Whats bags are you looking at using, and how are you going to control the pressure?
Aug 24, 2011 18:34:42 GMT
I was thinking something like these at the rear and these at the front
1989 500SEC
1968 W115 4.2 V8
2000 CL500
