naki
classic, 24 years and not even started the next project! well, i hope you do start it. and look forward to seeing this DD6 in all its glory on the road one day so.
i have a jag thats been waiting 3yrs to properly get going with, i have started details and parts accumulation for it. hope to finish in under a decade if poss!
90 Range Rover Vogue SE 3.9 V8 LPG, Lifted & modified for Off Road 93 XJ40 3.2s- awaiting 4.0 Manual conversion 91 XJ40 3.2 Sport Pack MANUAL (project) 93 XJ40 4.0 Sovereign- Daily Driver 91 XJ40 4.0 Manual 92 XJ40 4.0 XJR Manual 93 XJ81 6.0 Daimler Double Six
foxy99
Finally found a parts list reference for the 1/4 panel fixings, in the Series 1 XJ12/Double Six book. It still doesn't really tell the full picture tho since it shows they are split 7:9 not 6:10 as you might expect since there are 10 captive nuts and 6 open hole fixings
foxy99
Hi WL (Waxy?). I sometimes use magnets but with small pieces like that they can obscure the job. With the little ears I can extend them past the area I'm working on then hold them with magnets. Anyway. With the IRS cage away for painting my attention turned to the shocks which will be fitted to it. I was lucky enough to get 2 new XJ shocks from Ebay for £9.99 (just under £20 after P&P) back in March. The guy actually listed another 2 a couple of days later but I missed out on them thinking he'd accidentally re-listed the ones I bought I can get 2 more the same for around £46 each (usually listed as being for series 3 only) but having got the last 2 for nearly ten times less am not parting with my money yet. Offering them up to the original shocks they look a good inch shorter which got me thinking maybe the are only for series 3 but I checked the series 1,2 & 3 parts lists tonight and they all show the same part no. which suggests these shocks will fit any XJ model despite being shorter. I also found that there is a removable sleeve inside the top eye of the shocks ( C.17012) that you can transfer to the new shock. Still find it hard to believe the the car was driven about before I owned it with one missing. Then again I also found out that it was driven with a compomnent missing from the power steering pump! I found it on the subframe and was gonna throw it away. I won't go into the whole thing again as I posted it on this thread some time ago (March 27 entry) retrorides.proboards.com/index.cgi?board=general&action=display&thread=107118&page=7sleeve C.17012 inside top eye pushes out easily new QH LiP shocks are shorter than originals. 2 more needed valve from inside the PAS pump had been lying on subframe since hoses were changed in mid eighties
Last Edit: Aug 8, 2012 2:03:20 GMT by foxy99
foxy99
With money (£54 to be precise) that might have been better spent on Mapp Gas torch (to tackle the, as yet unresolved, fuel pipe fitting) or caliper pistons or engine service items I got the IRS cage sandblasted & powdercoated. Looks pretty good but you then stray into dangerous territory where you try to make the rest of the IRS look nice. I have bits of it steeping in Oxalic Acid just now but its nowhere near as good as that Deox C stuff. Much cheaper right enough. Also got a few more nuts/bolts/washers from the very efficient Spalding Fasteners (Trimm50 on Ebay). Again, I'm no going to go mad a replace every bolt with stainless but these latest ones are for the rear bumper and as that wasn't mounted on the car when I bought it some of them were missing so I did actually need new ones. Also I just got zinc bolts & nuts as they were cheaper/in stock. The company sent me 3/8 UNC bolts instead of 3/8 UNF and actually sent me the correct ones the next day free of charge and said - keep the wrong ones. You can't say fairer than that IRS cage looking nice in powdercoat£45 + VAT by ESP in Possil, Glasgowa few more fittings. this time for rear bumper. bolts which hold bracket to bumper blade were badly corroded
Last Edit: Aug 10, 2012 2:16:01 GMT by foxy99
rear cage look nice now shame to fit it back and get it all dusty again, don't forget to run a tap throught the fixings as the treads will be full of paint I too have ordered all new bolts they are much nicer to work with even though they don't have a lead
foxy99
Hi Rob. Is the lead the unthreaded nose at the front of the bolt/screw? I've noticed a lot of the originals on the Daimler are like that. I spent a bit time tonight cleaning up threads etc on various bolts etc tonight but the guys at ESP actually masked of the captive nuts on the cage. The only threaded bits on it are 8 nuts on top which I believe are for the exhaust hanger brackets. Each bracket on my car only takes 2 bolts (on the series 1 V12 it was only 1 for each bracket) so I'm guessing the other captive nuts were for different positions if it was a 2.8 or 4.2, instead of the 5.3 Also dug out the tie plate which I took off years ago and it looks pretty rough next to the newly painted cage. I took the time to examine the 'Heath Robinson' exhaust mounting bar that was fitted to one side. New bars are £28 and its a superceeded part no. so not sure whether to get them or not. You also need 4 plastic collars which are £10 a piece! The stud used on this thing is a mystery. It has an Imperial thread at one end 3/8 UNF (24TPI) with a 9/16 spanner size nut and on the other end it has a metric 10 x 1.50 thread with a 17mm spanner size Whoever knocked it up has put the 17mm nut in then ground the stud flush with it so perhaps they tapped the metric thread onto it also as I can't imagine a mixed thread component like this ever was made. It is possible the 24 TPI thread at the other end is actually M1.00 but neither a 14mm or 15mm spanner would fit it and the 9/16 was perfect fit. original IRS tie plate typically oily & rustya bit bashed too. should have perhaps tidied it up and had it painted with cageHeath-Robinson substitute for original Jag part from passenger side of my IRShome made exhaust mounting bar has metric nut at one and and imperial at othermetric thread file on RHS and imperial on LHSM10 x 1.50
Last Edit: Aug 11, 2012 4:05:45 GMT by foxy99
What a build! You sir are an inspiration! I cannot wait for this big cat to return to the road!
foxy99
Last Edit: Aug 13, 2012 10:05:50 GMT by foxy99
I continue to be impressed by this thread. I have nothing more in depth to offer, you seem to have it all under control.
naki
Aug 18, 2012 13:32:06 GMT
i just hope you don't have significant engine trouble after its been laid up for so long! i hope its been started and run in the 12yrs! thats the last thing you need after all the hard work on the bodywork./ it would be great to see it drive, even if its not mint.
that rear valance is one huge mud trap from what i can see. was it full of dirt flicked off the back wheels when you took it apart? just how many layers of underseal and wax will it take to protect it in the future?
foxy99
Aug 19, 2012 14:59:59 GMT
Volksangyl Thanks. I appreciate that. As I've said a few times now I think I'm through the worst of the build now and all that's really left is mechanical things and, armed with my parts lists and square eyes, I'm in control mentally taking each section at a time as the next challenge. naki Yep that picture shows what a mudtrap it can be. One of the reasons I cut the old valance as far down as I could is so that it could be replaced again, if need be. I didn't use the whole depth of the repair panel so if one were to be fitted again there is still scope for it. As for the engine. Unfortunately it's not been run at all in the 12 years I've had it and I believe it last ran in 1986. I have a pretty firm belief that as the engine isn't seized and it's only done about 60k miles it should be a fine. We'll see..... In the meantime here are some pictures from Saturday afternoon where I grouped together and laid out all the exhaust parts I have for it. Old and new. Apologies if I go overboard with part numbers etc but I find it quite interesting. I've been scouring the net for cheap exhaust parts for some time now and recently came up trumps with a LHS front downpipe C.43398 for £5 and a LHS link pipe C.4340 (long one that runs under length of floorpan) for £20. Had to pay for postage as well but considering I paid £42 for the RHS downpipe about 10 years ago it's not too bad. As there are 6 parts, left and right, in the exhaust system and mine has been stored in pieces in the loft of the barn has been tricky keeping track of what was damaged/missing/servicable. Coupled with the fact that there are also different lengths of link pipes and downpipes and the silencer part no.s changed and can be listed under Jaguar part no's or GEX it was good to get it all out and get a handle on where I am. A slight disappointment is that the new LHS link pipe is about an inch or two longer than the RH one although the parts no's are correct. The series 1 and early series 2 V12s had longer downpipes than the later series 2 and therefore had a shorter link pipe but there were also 2 lengths of link pipes, as you had 2 door and 4 door cars. When the shorter downpipes came in longer link pipes were needed and again in 2 lengths for 2 or 4 door. By the chassis no. my car should have the short downpipes and long link pipes but it was definitely fitted with the long early downpipes as it was only numbered 103 cars later than the change point. I'll need to offer the parts up to the car to establish if the RH side one is too short or the LHS one is too long. If it is the LHS link pipe which is wrong I could search for an early short link pipe as I picked up an early long LHS downpipe a few years ago. I think the early parts are very rare now tho so that may be a long search Anyway. Here are the pics from Saturday laid out for examination for 1st time. front to back back to front. V12 exhaust system fittingly has 12 pieces in total - if you include chrome tailpipe trimslater (short) O/S C.43397 & N/S C.43398 downpipes with early (long) N/S downpipe C.37482passenger side mid silencer replaced with genuine part C.35405 some time before 1986driver's side back box (top) also replaced some time before car laid up. genuine part C.41591 usedrear ends of long under-floor link pipes all have same angle bendsearly downpipe and early link pipe should have same combined length as late downpipe and late link pipe. why is this LHS late downpipe/link pipe combo a shade longerlate longer O/S & N/S link pipes flank remains of early short N/S one. differing lengths of new ones is worryingdriver's side over-axle pipe was at some point twisted under weight of mid silencer and I hacksawed it at damaged bit to get it off car many moons agopassenger side back box probably the original. short front-pipe has rusted away completely. over-axle pipe was hacksawed to separate it when in-situ. welded back together again tho
Last Edit: Aug 20, 2012 9:59:53 GMT by foxy99
foxy99
Last Edit: Aug 21, 2012 9:58:31 GMT by foxy99
foxy99
Last Edit: Aug 22, 2012 2:51:13 GMT by foxy99
naki
i don't understand why they go around the shocker mount here. seems to be the same on the XJS too? looks like a decent enough repair. its a constant battle between time and doing the job right i think. but considering how long its taken to get to this stage, i think its good you are picking up the pace. are you planning to spray the car before its on the road?
foxy99
Aug 22, 2012 23:50:44 GMT
Hi naki. I reckon they go here because there was no rustproofing between the inner wing and the shock mount-bracket spot welded to it. The rust then breaks out through the thinner panel, which is the inner wing. I have got about a litre of the right colour paint (unthinned) which should be enough to do the visible repaired areas (rear valance/sills/rear arches/front wing noses). It was about £80 so I dare say I could shell out for another couple of litres and do the rest of the car....one day Anyway. Here's a gratuitous shot of a bit that I did back in the winter. Don't think I've covered the arch repairs yet but after it being without one for years the new one was on in about 2 nights.
Last Edit: Aug 23, 2012 1:14:55 GMT by foxy99
foxy99
Back to the present (future?).... When I originally removed the IRS (to get the brake calipers out, around Feb 2011) the mounts ripped so I bought some used ones and when I put the IRS back up had a bit of trouble getting the locating bolts back through. In fact one wouldn't go in at all. Before I put it back in the last time I tried all the mounts on the car individually and they fitted but not once they were attached to the cage. So, now that the IRS is off again and the cage is empty I thought it would be a good chance to sort this issue out as it's much easier to manouvre etc when it's like this. There is still a problem and it can't be the first time it's happened because in the Jaguar Enthusiasts' Club/Kelsey Publishing Limited book Jaguar/Daimler XJ6 Restoration they had problems and gave up on the mounts they had and got new ones which fitted Pg 80 pic 17 "...was wheeled to the car on a trolley jack where we soon discovered that the boltholes in the subframe mountings did not align with the originals in the chassis members. The job was held up while we awaited alternative replacement mountings."There is no scope for moving the mounts on the cage, desipe an elongated bolt hole for the bottom stud on each one, because the other 2 bolts for each mount have no scope for adjustment. empty cage is light and can be put up with no stresses or strains on the mounts which might affect positioning front left. could go with a bit of leveringrear left. not so goodrear right. not too badfront right. probably the worstbrackets seem a bit wider than necessarycage has slots which suggest adjustment is possible but bolts above have no movementI'll investigate further tomorrow. Am thinking it's a series 2 - series 3 part no. supercession problem
Last Edit: Aug 24, 2012 1:39:15 GMT by foxy99
CaptainSlog
Club RR Member Number: 180
Aug 23, 2012 14:24:46 GMT
Maybe try bolting the mounts to the body and put the cage on after - the slots would make sense then.
foxy99
Hi CaptainSlog. That might be worth a try. I reckon I could get the brackets to attch to body that way and the studs into the slotted holes but don't think the holes for the other two bracket to cage bolts would line up then. I checked my parts lists last night and the series 3 brackets are part no. CAC3067 while the series 1/series 2 are C.29344. Wonder what the difference was.... Back in reply #122 (Aug 8th) I was fretting over the new rear shocks and have been trying to find my coil spring compressors ever since to swap the springs etc to the new shocks. I eventually found one hooked on the wall where my stereo is that I use every night and the other in the pram store at my flats Strange thing is I can't remember ever using these before. They have a very handy attachment for a 1/2" drive ratchet and only one clamp is threaded so they are easy to use. The ones I do remember using but didn't find had a coarse 2 way thread and were a pain to use. Armed with my newly found, better compressors I was keen to de-spring all the shocks tonight but arrived at the barn to find I'd let the electricity run out so only got one done before darkness fell. The spring etc seems fine on the new ones despite the apparent difference in length so I'll prob take the plunge and get two more. 1/2" drive ratchetable compressors had spring compressed quickly and safely with tension off and a little tapping the bottom collets shake loose down to component parts springs etc seem ok fitted to new shock Also didn't get chance to investigate the IRS mount issue either tonight due to lack of light. Won't be back till Saturday now, as going for a pint tomorrow night
Last Edit: Aug 24, 2012 0:34:32 GMT by foxy99
foxy99
Aug 25, 2012 14:50:23 GMT
Just found this reply I got from a guy in Florida when I posed the question about the mounts on another forum last March
'I got the impression that the mounts are designed to be installed on the car first. Once installed on the car, the protruding bolt on the bottom of the mount is pointing down at an angle, not completely vertical. The elongated slot is therefore necessary, rather than a circular hole, as the slanted bolt would not go through a circular hole when the IRS cage is raised into position.
I hope the explanation makes sense - it's a bit hard to envisage. Anyway - that's my belief on the reason why there's an elongated slot when there's really no adjustment possible for the mount positions.'
Makes sense I suppose.
dbdb
Aug 25, 2012 20:48:11 GMT
'Epic' is a horribly overused word nowadays, but this is such an enormous undertaking it is one of the few which qualifies as an epic build!! Marvelous to see you persisting with this over so long a time and with such effort. It is worth it! - The S2 Double Six Vanden Plas is one of the most beautiful car ever made, in my view. Together with my XJ40, it is my favourite Jaguar saloon - maybe even my favourite (I'd better whisper that, my old beast has big ears...) ;D
David
