foxy99
Last Edit: Jul 23, 2012 9:53:17 GMT by foxy99
bstardchild
Club RR Member Number: 71
Always love seeing progress on this
foxy99
Last Edit: Jul 24, 2012 2:39:14 GMT by foxy99
About 3 cups of coffee later & I've finished reading your thread from start to (current) finish, Brilliant !! Bookmarked now & awaiting future updates, you work is excellent, :-) :-)
foxy99
Thanks Alpina99. I have missed quite a bit out on the repairs I did to rear of body but will post them up in due course. Tonight I had a further look at the diff. You need a special puller to dismantle the hub to get the drive shafts out which I won't be doing so will be limited to cleaning them up in situ. I will however be able to remove the lower wishbone to de-rust and paint and also the diff cover. I took that off tonight and there was a lot of oil in it which I don't think you could drain out via the plug as it sits quite high up. I'm no oil expert and the car has only done 60K miles but the oil looks pretty black so a change will probably be beneficial. I also found someone selling the special cone-shaped diff bolts but its a set of 6 (3 sizes) at £30. If the chap won't sell them individually I'll need to just buy the set as I can't see how I'll get another. Looking online it appears a few other people have had them break off in the castings leading to much heating, drilling and snapping-off of 'easy outs' & taps so I should perhaps be thankful my one came out so easily and stump up the cash. rusty diff crying out for some paint ID tag and another and one more old oil easy to drain out with cover removed. can't see how you would achieve this through the drain plug which is a couple of inches from bottom of casing
Jul 25, 2012 15:57:17 GMT
That was a good read. Lot of people would have given up ,far play to you for carrying on.
The louder you Scream the faster we go
foxy99
Thanks broadie777. The strange thing is I have never thought this car was in that bad condition. When I look back on what I've done it all seems pretty straight forward and I wonder what took so long. That's easy to say in hindsight tho. I was always however comparing this project against my next one which is a lot worse (Hillman Imp pick-up). I'm currently at the tidying up lots of small bits and loose ends stage which led to re-visiting one of the first repairs I did on the car. It was on the RHS rear chassis rail/box section and back in 2004 when I did this I was trying to avoid stripping the car right down so worked around parts such as the brake hoses and heatshields, rather than remove them. I did most the welding on this part from inside the inner sill but it always bothered me how it looked at the back so tonight, now that the IRS is out, plus taking off the exhaust heat shield from under the rear seat pan I got in to have a good look at it and clean it up to run a weld from this side too. I have to admit I'm quite pleased with the work I did back then. It was a non OEM repair panel and needed a fair bit of adjustment to fit but it turned out well strange matting material on seatpan needs to be peeled back to get at rivets that hold heatshield to underside. lots of glue underneath makes things look worse than they actually are access for welding torch was restricted when IRS & heatshield were in placedifferent camera settingrepair panel was a bit shy so extra piece had to be let inIRS out of way give good access to 3/8" steel fuel feed pipe. this one sound enough to leave as ispropshaft UJ disconnect to remove IRS. needs cleaned up to make fitting new UJ easierwishbone removed from hub carrier for cosmetic worklots of degreasing to be followed by paint stripper then oxalic acid dip
Last Edit: Jul 27, 2012 3:03:57 GMT by foxy99
foxy99
Jul 28, 2012 18:15:37 GMT
Last Edit: Jul 28, 2012 18:23:50 GMT by foxy99
bstardchild
Always enjoy this thread on so many levels but manily because it give me inspiration to continue my projects
Just read from start to finish, good work! I've got a series 3 XJ, looks nice as it is. I reckon it might be a little rusty behind the panels... Lol.
I'm not wrong, you just don't agree with me. There's a difference!
Jul 29, 2012 10:24:19 GMT
Awesome stuff as always Sir. I doff my cap to you. I'm off to paint my front panel. Thanks for the inspiration.
1980 Derby GLS 1992 Rover 216 Gti - Sold 2006 Hilux - Sold (boo hoo) need a 2wd pickup. Anyone? 2009 Avensis Tourer - Gone 1993 Mk1 Golf Cabby 1983 mk1 golf. Project rust bucket 1998 Toyota Corolla. Project crash repair 2007 Volvo V70. Daily for sale!
Looking for a winter project - any suggestions?
Jul 29, 2012 11:54:00 GMT
Am amazed and humbled at the lengths some people go to to get great old cars rolling once more!
Currently: 1974 Beetle - Golf -
Previously: e38 735i, e34 525iSE, 1972 Beetle, 1991 Scirocco Scala, Morris Minor, 1983 Polo Breadvan, 1991 Mazda MX6
DutyFreeSaviour
Good God I thought I went through the mill with the Trump mess - I'd be tearing my hair out with this lot! Maximum kudos for the sheer amount of work, thought and thorougness you're putting in on this.
It'll be a stunner to be proud of.
Best of luck
steve900
Idle & Shiftless
Jul 30, 2012 10:32:05 GMT
Just read this from start to finish - bang goes my morning off work! Great rebuild - looking forward to more updates.
Saab 900 Saab 9000
foxy99
Last Edit: Aug 3, 2012 2:59:05 GMT by foxy99
More monumental work on the jag ;D do like the methodical way you are going about it, l'm a bit all over the place at the moment doing bits. Reading further back about the mirror on the wall, it could be a adam ant check, just to check you haven't got an embarasing grease strip across your face before you go home lol
foxy99
Thanks Rob. As I said I'm quite enjoying the closing stages methodically tackling groups of parts. Got the replacement cone shaped bolt, for the one that mysteriously snapped, today only problem is it was nearly £10 after P&P but as I said before would be feeling a lot worse if I was trying to get the remains of one out the casting I have also been piecing together a cheap exhaust system over the years and the last place I thought to look was a dealer. David Manners had a LHS link pipe listed at a very good price. There are several of these depending on whether the car is 2 door or 4 door and has short or long downpipes. This one is the right one for a 4 door with short downpipes but as the part no. sticker on it is almost unreadable due to age/damage can't be 100% sure. C17010. £9 after VAT & P&Phopefully LHS link pipe C.43430/GEX170. £24
Last Edit: Aug 4, 2012 15:42:50 GMT by foxy99
naki
impressive dedication over such a long term project. i doff my cap to you sir.
keep the pictures coming
out of interest, when you first started did you have the idea if was going to take more than a decade to even get to this stage? i wish i was that patient, but i don't think i could wait that long to get a car finished.
90 Range Rover Vogue SE 3.9 V8 LPG, Lifted & modified for Off Road 93 XJ40 3.2s- awaiting 4.0 Manual conversion 91 XJ40 3.2 Sport Pack MANUAL (project) 93 XJ40 4.0 Sovereign- Daily Driver 91 XJ40 4.0 Manual 92 XJ40 4.0 XJR Manual 93 XJ81 6.0 Daimler Double Six
foxy99
Last Edit: Aug 6, 2012 2:18:36 GMT by foxy99
