hi, i need my drum brakes redrilling to landrover stud pattern, does anybody know where i could get this done around the leicestershire or thereabouts area ? many thanks in advance.
any reasonable machine shop should be able to help, I've used tunnicliffe engineering in hinckley for the odd car job in the past, but but do most stuff myself these days
landrover is a very big stud pattern- 5x6.5" iirc.
what are you wanting to redrill? few cars will have enough metal in the hubs to do that.
I'm doing a baja bug,the rears are already sorted by using early 5 stud bug drums, but I'm using 4 stud bug drums on the front,which I'm hoping to have redrilled and perhaps change to studs instead of the bolts that screw into the drum ?
