con2k
Hi all. The fountain of knowledge that is the technical bit of RR should be able to help me. I've had a quick look online and on here but think i've just confused myself further with the information I picked up. Need to know what it all the numbers mean. Some fo them I think know, but would prefer to be told incase I'm wrong. Basic Engine spec: 1640cc Kent Crossflow Fiesta engine Electric fuel pump Aldon Dizzy Magnecor leads Kent 244 cam 1300 bowled pistons enlarged valves, ported head, steel rocker posts lightened and balanced bottom end. I have had the Twin 40 DCOE Weber carbs it came with serviced and recently rebuilt the engine. Back to bare block, honed, balanced etc etc. Carbs were rebuilt and setup by a specialist just tweo days ago. (He is a friend of Stu from AAS in Newburn). He did it as a favor so I didn't get any direct contact with the bloke apart from telling him what car it was going on and its usage. Visually, he did a cracking job, they look great, to be honest, anything was an improvement on how they looked. He used genuine weber, or decent quality replacment parts. All the old parts were returned so I can see what was changed and he renewed a lot of the internals and set it all up. He said it'll need fine tuning once fitted to the car but did the best he could so I can get it running well enough to run in the engine at home. I'm very new to carbs. Before: After: His setup details: I would have typed it out but I cant read his writing 100% and may misinterpret what is written. Basically, what level of tune is this? Is it good/bad for a 1.6 fast road/track car. I notice he questions one of the settings (S/RUN) saying another one might be more suitable? I had a look online but it seems to give either the basics of carbs, or too much detail (for another engine) that I cant make sense of it based on my setup. Any help/advice would be appreciated. Many Thanks. Oh, I need to order a linkage kit too, the one it came with was in bits with stuff mising and I'd prefer a new/complete one. Any reccomendations?
Last Edit: Jan 5, 2012 14:08:48 GMT by con2k
barty
to be honest its best set up on a rolling road as they will get it spot on for you. You will get a load of advise which will only confuse you and may do more harm than good. It will cost a few quid but in my view its money well spent, you should even get a power print off too if thats what you want but make sure you tell them its a new engine and the spec of it too
con2k
Cheers barty.
I've been told that it's setup enough to atleast run in my cam (20mins 2-3krpm) without the engine dying on me or being really lumpy trying to run in as a result of carb failure. So as long as it does that and I can then run in over a few miles, I'd be taking it for a rolling road anyway. I just wanted to get my head around what these numbers meant so when the time comes I have a better understanding of what I can get out of it and what they will do when setup properly.
Weber 40 DCOE Carb Setup???ChasR
@chasr
Club Retro Rides Member 170
From what I have read you should not drill the jets on either Weber or Holleys since it is very hard to mimick the smoothness of the correct jets. As above though a rolling road who is familiar with Weber DCOEs should see you straight .
barty
If you go to a good rollers they will have all the jets you will ever need. Ive been to a few rollers in my time and some of the not so good one have drilled jets before with no real problems but of course its best to have the right size jets in the first place and a good one will always have the correct ones in stock. Good luck and don't forget to tell them its a new engine, the spec and what you want to use it for. Always make sure you have checked all fluid levels and check your tyres too for pressure as well as any wear, they say you can gain power on the rollers by adjusting the trye pressures lol
srun is slow running/idle jets . the F number is the air bleed and the first number is the fuel orifice size. not all various size slow running jets are available anymore so they may have to resort to soldering and drilling. as long as care is taken in the drilling and cleaning up the burrs then drilled jets are fine. driveability is always the hardest to set up and can be a lot more than just changing jets. auxillary venturies are the 'sensor' for the fueling so different size ones of these can be used to make the progression more or less sensative as required. float height will also have a profound affect on slow running and progression. book setting may not be the ideal but it'll be the place to start. raising the float height will make the main jets come in slightly earlier if it goes weak on progression etc but it'll make virtully no difference on full throttle. even modifing the progression holes can make a difference to driveabality, thats why certain carb part numbers work better on some engines rather than others. i think the prefered carb for Ford engines are DCOE9's? but by cunning modification any carb type can be made to work. what you have will be fine to start with because you need to start somewhere. F11 on the emulsion tube rings a bell on Ford engines but i wouldn't worry until the engine has been dynoed to see what the fueling does. 40's on your engine once set up should be a good compromise between having good low end power and just sacraficing a little power at the top. can you update the thread with what the tuner finally ended up with so anyone else searching will have a bit more info to work with . cheers
Hi all, 1st post on RR! The advice you'd been given re getting it set up on a rolling road is good but I would say that the chokes/jets specified are likely to be a good base starting point for your engine spec. Key thing when setting up DCOEs is to get the choke size right and this then largely determines the jets used. I would say yours is spot on at 34mm. The spec of your engine is very silimar to that of a 1700 cc Caterham SuperSprint (the main difference being yours has a 244 cam and the caterham engine uses a 234). Well known engine specialst Roger King specifies the following set up for those engines: Choke 34mm Main 130 Air 140 Emulsion tube F16 Slow run 50F9 Pump 35 For further info, try Dave Andrews homepage and look at his jetting program for DCO & DHLA carbs here www.dvandrews.co.uk/This should give you a good & safe starting point for any jetting changes Finally, do you know how to set the idle mixtures & balance the carbs when you install them, as this will have a big impact on their smooth running. If you're new to these carbs, a good book such as www.amazon.co.uk/Build-Power-Dellorto-Carburettors-Speedpro/dp/1903706750 will be invaluable. this covers all aspects of servicing, jetting, installation and set up. Out of curiousity, what is the DCOE number stamped on top of the carb? it should read DCOE then a 1 or 2 digit number. When set up properly, these are amazing carbs! Good luck with it Phil
srun is slow running/idle jets . the F number is the air bleed and the first number is the fuel orifice size. Bozwell, sorry to correct you but the F number most likely relates to the emulsion tube number - here an F16 which is correct for this engine type/spec (and a bit pricey if you have to change it) the 'air' number refers to the air corrector, which affects the mixture at high engine speed Just wanted to avoid any confusion
barty
see what i mean about confusing advise lol,
see what I mean about confusing advise lol, Agree totally barty! i've got a xflow powered westfield with 2 x dcoe18 40s - best source of reliable online advice I found was the blatchat site (caterham owners) and the wscc boardroom (westfield). Lots of guys on there are/were running these carbs on xflows/pintos/zetecs/XEs/BDs etc and there's some great guidance there. I really struggled to find a garage/rolling road that really knew how to fault find and tune these so I ended up reading the speedpro book and the haynes book and got to the point that I can happily work on set of dcoes, they're actually very straightforward to work on. The dave andrews jet program gave a very good starting point for the jets on mine too which were waaay out when I first bought the car. edited to add - con2k, do you have a fuel pressure regulator fitted with your electric fuel pump? if not, you should invest in one - dcoes don't tolerate a fuel pressure much over 3psi and most electric fuel pumps put out more than this, eg facet red top.
srun is slow running/idle jets . the F number is the air bleed and the first number is the fuel orifice size. Bozwell, sorry to correct you but the F number most likely relates to the emulsion tube number - the F number on the idle jets is the one i was refering to, ie 50F9, the F9 is the air bleed (air corrector) for the idle jet. but it doesn't really corrolate to the size of the air hole other than a designated number for that size hole. same as with emulsion tubes, numbers don't mean anything other than a sort of part number. emulsion tubes are a black art to sort if they need changing as the jetting used will totally change with an emulsion tube change. getting cams matched to the compression and matchd to the ignition timing will also have an affect on drivabilaty. i worked on a rolling road for many years and still tune carbed racing Jaguars. as i said before, flat out tuning is easy, it's drivabilaty that will cause all the headaches
Bozwell, sorry misunderstood which F number you were referring to there! Agree totally with what you say.
i didn't have much luck with 45F9 idle jets on my 1600 xflow (A2 cam), they caused the engine to spit back occasionally at low engine speeds, it was much happier on the 50F9s
see what I mean about confusing advise lol, there is no confusion . it is agreed the jets are a good starting point, next stop is the rolling road. i really doubt the op was going to attempt to fine tune the carbs. going back to the first post the op wanted to know what sort of tune the jetting is. well the jeting isn't the 'tune' aspect, the jets are to supply the correct amount of fuel and air mixture atomised as best as possible throughout the rev and throttle range. the 'tune' part is the size of the carbs and venturies tuned to the potential power output of the engine. fitting larger chokes will allow more airflow at the top end but may hurt bottom end performace because the airflow is too slow to properly atomise the fuel to produce a good burn. basically carbs are always a compromise between low end power, high end power and drivabilaty. 40's with 34mm chokes is a good low to midway point between the two. full on race engines will run 50mm carbs with 45mm chokes to get all the power but will be a pig around town. another 'tune' aspect could be the length of the carb trumpets. the total length of the inlet tract can produce a small supercharge affect at certain rpm ranges because the sound pulsewave travels back and forth with a high pressure wave in front of it. the ideal point is to have the soundwave travel towards the inlet just as it opens. also with higher duration cams the compression ratio needs to be higher because the inlet valve opening earlier and closing later lowers the dynamic compression ratio. never use high duration cams on low compression engines, they just don't work. huge inlet ports can really hurt performace unless your revving to 10,000 rpm. that is another art in itelf to get 'just right' so you see the jetting is really just the final stage to get the fueling right. the 'tune' is everything done to get to that stage and can easily be the difference between a good engine and one that really flies with no apparent difference in parts used other than it all works in harmony
con2k
Some fascinating information there, just some details to help from me:
I've had a car put on rollers. Not this one, just a standard fuel injection car. So a carb 'setup' will be a new experience from that point of view.
The car is a project. The engine is built up and now the carbs, but combining the two, cable linkages, fuel lines (vaccum hoses?) etc are not. Once the shell is painted and the engine is fitted and run in, I will definately update this thread with the details of Power, torque and any changes made.
Yes the car did run and will run a fuel pressure regulator. an FSE unit was removed and will probably be refitted.
As seen in the picture, it says the main jets have been drilled. This could be the current rebuild guy, or a previous person. I was not told which.
Westy, checking those links out now. The engine spec is very similar. But the higher lift 244 cam means it's guna be pretty poor low end anyway I'd have thought. Will a good setup help with low end if setup in such a way? The roger king spec has 130 Main and 140 Air compared to my 135 Main and 155 Air. (I wouldnt know at the moment with my current level of understanding, if this is a big difference). Then again, it's a different engine, different cam and variations in build quality/experience/understanding are bound to vary the reason for these settings.
The carbs are 40 DCOE's. A pair of '40DCOE 28' - non sequential serial numbers. About 2000 units apart I think. I don't know how to initially set them up at all. I told the guy rebuilding them that I had no understanding and it was new to me. I wanted them to be suitable to run in my cam for 20m mins without bogging down or being lumpy and then I can look at how they run more accurately on the drive.
Bozwell, your right in saying I wont be fine tuning the carbs myself. Atleast not initially. Maybe once I get my head around it ALOT more and alot later. So a High Dur. cam and Low comp engine aren't a great combo. Depends how High/Low mine is. The 244 comes in quite late and the 1300 pistons decrease the compression I think as they are bowled instead of flat topped (ignoring valve seat cut out requirements). A common level of specification (In fact I think the riginal engine work was carried out by Vulcan Engineering, but back in the mid 90's and approx 8 owners since then. Who knows what happened between then. All I remember is the car revved very high for a kent xflow and was nothing, nothing, nothing then really really lairy.
I think my best bet is to do some furhter research into the variations and then I'll have a better understanding of what I should expect. Unless someone comes in and tells me the DCOE28 versions are completely wrong for my engine? - I'll be fairly disappointed after paying out for the work, but would assume the jet settings I was provided with are the reasons for the Version numbers and are now matched to the 1640 xflow.
Many Thanks to all.
Last Edit: Jan 8, 2012 1:41:08 GMT by con2k
it says the main jets have been drilled. This could be the current rebuild guy, or a previous person. I was not told which. To me, that suggests the main jets were a smaller size and the builder has drilled them out to a larger size. Main jets are readily available and cheap so would be easy to swap them for a known new set. Will a good setup help with low end if setup in such a way? The roger king spec has 130 Main and 140 Air compared to my 135 Main and 155 Air. The only manual adjustment that can be made is to the idle mixture screws, the rest is taken care of by the chokes/jetting and is fixed if you see what i mean. what would really help is getting the carbs synchronised propely once they're installed. There's a few different ways to do this but i use a syncrometer the same as this www.burtonpower.com/web98001-000.html The Speedpro book gives a really clear explanation of how to do it as well. Bear in mind that the choice of air corrector is dependent on the main jet choice, if you're changing the main jet, it's good to consider a change to the air corrector too. A basic guideline is that the air corrector value should be 50 more that the main jet, ie 120 main should have 170 air. This is only a starting point though and in practice is rarely the case (as per the RK spec). More often than not, the air corrector is a lower value than this - the air corrector influences mixture strength at high rpm, the last place you want it running lean lol The lower the air corrector number, the richer the mixture will be at the top end. The carbs are 40 DCOE's. A pair of '40DCOE 28' Per my Haynes weber manual, the 40 DCOE 28 carbs were originally fitted to the Alfa Romeo GT Junior Super 1300. The chokes/jets when originally installed (as a pair) were: 28 mm chokes 4.5 Aux venturi 112 main jet 50 F11 idle jet F16 emulsion tube 210 air corrector 35 accelerator pump jet 1.5 needle valve the fact that your spec is very different shows that the carbs have been changed significantly from their original specs and tailored to a tuned xflow. There were 2 basic types of DCOE - emissions and non emissions spec, the latter being more tunable and giving more power. The good news is that your 40DCOE28s are the the latter type, the easy way to spot this is on the front flat face of your carbs, there is a large circular vent hole above the left barrel on each carb when looking down the barrels of the carbs from the trumpet end - this is present on the performance (non emissions) DCOEs and is either much smaller or blanked off totally on the emissions spec models. the 1300 pistons decrease the compression I think as they are bowled instead of flat topped (ignoring valve seat cut out requirements). xflow pistons are bowled as standard, their design is to have the combustion chamber in the piston and have a flat head. My understanding is that the 1300cc pistons are a cost effective way to raise the compression a bit without going to the expense of forged pistons, but as the pistons were only designed to run in a 1300 cc engine, their longevity is compromised in a tuned 1700cc engine. This is exactly what Caterham did with their 1700cc SuperSprint spec xflow, and the Roger King jetting i mentioned in an earlier post would most likely have been for an engine with these 1300 cc pistons. For setting the carbs up for the 1st engine start, the Des Hamill/Speedpro gives a really good write up. In summary though,check the float heights (15mm full droop, 7.5 mm just touching the needle valve, all measured from the carb cover inner face) start with each idle mixture screw 1.25 turns out from light seated, adjust the central balance lever such that visually the butterflies are as synchronised as possible. DCOEs don't use a vac advance so this should be blanked off on the dizzy if there is one fitted. There will be a screw on one of the carb bodes that pushes on the central balance lever, this is you idle speed adjustment - adjust it so that the butterflies are just cracked open & you should be good for a 1st start where you're looking to bed the cam in at around 2-3k rpm. This is a very quick and dirty brief summary & there are lots of other things you'll want to check before starting up, a good book is invaluable for this Let us know how you get on or if you have any other Qs
The roger king spec has 130 Main and 140 Air compared to my 135 Main and 155 Air. if you tried both of these combinations one after the other and watched the mixture through the range at full throttle i would say the only difference would be slightly leaner at the lower part of the rev range for the 130main and 140air. the mixture at the top part of the rev range should be about the same for both settings. why is this you ask? i'll try to explain so when you see what the tuner is doing it'll hopefully help your understanding of what is going on. if you only had a main jet in a carburettor, as the rpm rises the mixture gets richer and richer due to the higher air flow increasing the venturie affect. to stop this from happening air is introdued to 'slow down' the fuel. that is the job of the air corrector. the emulsion tube then allows the air to bubble/froth the fuel to make it ligher so it reacts quicker at rpm changes. say with your 135 main and the 155 air the mixture was very rich at 3000rpm but good at 5500rpm. to lean off the fuel at 3000 will need a smaller main jet, but this will lean through the whole range which will hurt the top end. to richen the top end back up a smaller air corrector is fitted to lessen the braking effect of introducing air into the mix. with me so far? with a wild cam you will need loads of fuel at the top end. but this will probably make the bottom end too rich to even run properly. to over come this it may be nessesary to fit a smaller main jet but go way down on the air corrector. something like 125 main but a 100 air. (mains are small jumps in sizes and airs are big jump in sizes) you should be able to work out what this affect it'll have emulsion tubes will also help in changing the mixture through the range because they have different hole positions to bubble the fuel different amounts at different rpm ranges. for example an F7 is a lot more sensative at lower rpm so will be richer at the bottom and an F11 is leaner at the bottom end, irrespective of what jetting you use. F16 is about middle of the range. these take a lot more experience to know when to change them. so that was just the easy main circuit, but what about progression? at the flange end of the carb there is a little brass plug above each throttle. if you remove this plug and look down the hole you will see drillings. these are progression holes and each hole works to pass fuel from the idle jets. as you just lift the throttle to say 1100 rpm the butterfly will uncover the first hole and as you increase to say 1200 it'll uncover the next and so on (usually only 3 holes). by 1500ish the main circuit should just start to come in. for different carb types they are usually in different positions and for 16valve engines they usually have 4 progression holes. so the first step would be to set the idle mixture then open the throttle a tad to see what the mixture does. if it goes lean then a slightly larger idle jet is required so fit new jet, reset the idle mixture and raise the throttle a tad again. what if that is all now fine but as you open the throttle more it still goes to lean. you could try an idle jet with the same size drilling but a smaller side air hole (does the same as the air corrector on the main circuit which you should hopefully by now know exactly where this is going) fingers crossed the mixture at progression is now good. you shouldn't need to touch the progression holes but if there is still a problem then raise the float height slightly to see if that richens the progression. if not then drilling the progression holes very slightly (or even adding a fourth) may be the only answer. BUT there is no going back so if it goes wrong it'll be a pain to sort. many years ago i had an Aston martin DB6 with Webers on the rollers to sort progression as no one else was able to sort it. after trying every idle jet combination i got the micro drills out and drilled a fourth progression hole slightly larger than the rest. it worked ;D . i had to put a large idle jet in to resort the mixture but the difference was amazing. the owner came back a week later very happy to tell me it had also gone from doing 9mpg to 15mpg. anyway, with a big cam at low rpm the engine is very ineficient so you can actually run a lot more ignition advance at the bottom compared to a standard engine than you think. once your engine is running it'll be worth making an ignition advance graph to see what is going on. take an ignition timing reading from idle and every 500rpm from there. so idle 10 degrees 1000 rpm 10 degrees 1500 rpm 14 degrees 2000 rpm 18 degrees 2500 rpm 24 degrees 3000 rpm 28 degrees 3500 rpm 35 degrees 4000 rpm 35 degrees 4500 rpm 35 degrees 5000 rpm 35 degrees only as an example. max advance is usually around 3,500ish. you may find the engine likes 28 degrees at 2500 rpm but not like more than 34 at 3500 rpm. it'll be trial and error but can make quite a difference to how the engine performs at the lower rpm ranges. hope it all goes well for you as carbs once set up can wok really well. it's just finding someone who will go the extra and not be afraid to do more than just change jetting.
con2k
Someone to go the extra mile? Someone like you? lol. I have been recommended two local rolling road firms who can setup my carbs. But I'd travel nationally for someone with a good reputation rather than a local firm who I have been told by one person are good. (can't recall the name right now).
The information here has far exceeded my expectations. The details and information, backed up with examples is the reason I posted here knowing there are some with great knowledge of specific aspects of vehicles. I really hope to move along with the rebuild and get the carbs fitted. (give me a painted shell and it can be dropped in). I'll order both the Haynes and the SpeedPro books. I just hope they don't have conflicting information.
So all these adjustments can be made. And made by replacing/modifying the jets. So is it worth buying different ones to change between or would a carb based rolling road place have everything I could possibly need? (the same asked if I need the synchrometer or if I would be wasting time purchasing one with limited understanding of it?)
As with many others, my initial assumption on carbs was twin 45's are better than 40's, and both are better than a single carb. But the variations in so many settings can make, from what I understand, a very similar setup and bigger is not always better, depending on your engine spec. I would have thought an 'upgrade' to 45's would improve performance, but it seems that a rethink in advance and jets can transform the engine behaviour. In addition, it makes me rethink every carb powered vehicle I've come across and particularly my own when I last drove it over 4years ago. What felt like a lairy top end and flat bottom end, could be somewhat improved from changes to the carbs setup. I am beginning to see past the basics of engine components and that in fact they do work together. A flat low end power issue doesn't just mean spend £250+ on a lower lift cam to fix it.
I'll update again with questions I will no doubt have once I've read over this a couple times with the carbs in hand and also the paperbacks.
Thank you very much.
problem with jets are that they cost about £8 for four so a few sets will end up costing a fair bit when you only need one set. a rolling road set up for carbs should have quite a few jets in stock but they don't always have everything because it's £thousands tied up in jets, chokes, emulsion tubes etc. best bet would be to buy a set of micro drills and a drill holder plus a soldering iron. that way you can experiment with any number of jet sizes and once you have the combination that works buy that size new. This Four Stroke Performance Tuning book is well wort buying as it goes into loads of detail about every aspect of engine tuning for example there is a section on exhaust manifold design with ideal primary sizes/lengths etc and goes into good detail on how all the different collectors and mergers affect power. a carb syncrometer is about £30 but it'll be a good investment as the carbs will need a little tweak every now and then. it makes that job so much easier. probably find after a few goes setting up the balance and idle mixture you will just be able to get it right just by the sound alone.
con2k
Books on order. Is it worth getting the Haynes Weber manual too? The synchrometer isn't too expensive as long as its useful, and it seems it will be. My concern is as i have a fiesta, the carbs sit facing the bulk head. The synchrometer wouldn't fit in the gap, I'd be surprised if even the 90 degree adapter would fit which doubles the prices I've found on eBay. A rare photo before the car/engine rebuild showing the limited space between the carbs and bulkhead. Rather messy looking setup anyway. My thoughts were that the lack of filters and location of the carbs wouldn't be ideal.
does look rather tight. maybe use the old fashioned method of using a bit of hose and listen to carbs.
