psycho83
East of England
Rhythm and Booze
Jan 10, 2012 13:38:56 GMT
just a quickie here.
For an MOT, is it sufficient to secure a battery using some sort of canvas strap setup rather than a clamping system?
the new battery in my hillman has a much smaller footprint than the one that came out so the stock clamp is next to useless.
I will make something permanent but for the time being would strapping it be a pass? I would guess so as the battery will be secure.
cheers
Jan 10, 2012 13:53:05 GMT
I'm pretty sure loose battery is only an advisory, i made the error of taking my capri for mot a month or so ago and when i came to it, battery was flat, so a quick change was done and i totaly forgot abowt the clamps.
aslong as your going to sort it properly afterwards anyway!
MOT : Securing a batteryDez
@dez
Club Retro Rides Member 34
Jan 10, 2012 14:16:25 GMT
its a fail not an advisory.
pound shop ratchet strap has got me many a pass in the past on cars with missing clamps.
IDY
Jan 10, 2012 14:16:46 GMT
I'm pretty sure loose battery is only an advisory, I made the error of taking my capri for mot a month or so ago and when I came to it, battery was flat, so a quick change was done and I totaly forgot abowt the clamps. aslong as your going to sort it properly afterwards anyway! Item 1 HERE would suggest it should have failed
I will get round to finishing it at some point
Jan 10, 2012 14:22:30 GMT
I'm pretty sure loose battery is only an advisory, I made the error of taking my capri for mot a month or so ago and when I came to it, battery was flat, so a quick change was done and I totaly forgot abowt the clamps. aslong as your going to sort it properly afterwards anyway! Item 1 HERE would suggest it should have failed If he had taken it this year indeed, note the date on the bottom ratchet strap should be fine as long as the ratchet mechanism can't rub through any wires or short a terminal.
Last Edit: Jan 10, 2012 14:23:58 GMT by welshpug
IDY
Jan 10, 2012 14:30:43 GMT
If he had taken it this year indeed, note the date on the bottom Thought that date was to do with the addition of tow hitch electrics being part of the test
Jan 10, 2012 15:03:15 GMT
I've got cars though with a small ratchet strap or luggage strap but be aware that it is best only used temporarily. Webbing doesn't like battery acid much so if it passes over the vents on the top it'll rot through eventually.
Jan 10, 2012 15:05:50 GMT
naah, there's been loads of amendments and additions this year.
Jan 10, 2012 18:39:43 GMT
It could be stuck down with chewing gum as long as its secure
Jan 10, 2012 18:50:26 GMT
Yes, so long is it's not wobbling about.
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
bortaf
Jan 10, 2012 19:40:45 GMT
Mines held in with a bit of wood cos the braket is too big to hold the battery, anyway the new revisions have been susspended untill april aint they ?
R.I.P photobucket
IDY
Jan 10, 2012 22:21:54 GMT
anyway the new revisions have been susspended untill april aint they ? The towbar stuff seems to have come in - my 306 picked up an advisory for "O/S side lamp circuit not working on towbar socket"
bortaf
Jan 11, 2012 11:03:00 GMT
anyway the new revisions have been susspended untill april aint they ? The towbar stuff seems to have come in - my 306 picked up an advisory for "O/S side lamp circuit not working on towbar socket" Strange, i had am MOT yesterday and when i asked he said all the new tests had been put back cos the VOSA computor isn't ready yet (runs on windows i guess ) mind you if they had come in it would have been a fail not an advisery
R.I.P photobucket
maxlee
Jan 11, 2012 11:07:19 GMT
i have that as an advisery on every car for this, turned in to a joke with my mates "cars missing a battery clamp lee must have owned it" hurm might have to sort some clamps out soon then
psycho83
East of England
Rhythm and Booze
Jan 11, 2012 12:53:03 GMT
cheers folks, thats one more off the list.
g40jon
Jan 11, 2012 13:17:53 GMT
on my mx5 i fitted a non std size battery. i made a tray out of sheet aluminium, drilled a couple of holes in each side, which alloy a pair of short bungee cords to be hooked onto the sides of the tray, i then bolted the whole assembly to the boot floor of the mx5 (the battery is in the back as std) holds the battery very securely
Jan 11, 2012 17:05:21 GMT
pound shop ratchet strap has got me many a pass in the past on cars with missing clamps. Yep, baby ratchet straps have worked for me a few times. Sometimes as temporary fix - but some have stayed temporary for a couple of years
Jan 11, 2012 17:57:09 GMT
cable ties around the battery/under the tray have worked for me in the past
will
Jan 11, 2012 18:13:04 GMT
Inner tube and bungee cord for me. Clip on holds tight and no faffing with bolts FTW.
