mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
Jan 22, 2012 10:57:46 GMT
I hope someone can shed some light on this as I only bought this yesterday and was hoping for a little longer without problems.
The car is an 8valve, and I'm lead to believe that the box is out of a Corrado (albeit, converted to cable clutch).
Last night, whilst still getting used to the car, I lost the ability to select gears. The gears are there, but its almost as if the clutch isn't being activated fully. It has a manually adjustable cable and Ive tried it fully adjust/fully backed off and everything in between. The only way to get it in first is to start the car with it in gear and then it'll drive with a bit effort to get it into the other gears. But It won't go back into first without shutting it down and repeating the process.
I really hope whatever is up with it can be sorted without resorting to removing the box. My back isn't up to it and this was supposed to be something I could just drive without spannering too much straight away.
Please help....
Last Edit: Jan 22, 2012 12:37:29 GMT by mk14dr
Jan 22, 2012 11:17:50 GMT
Weird that!,does the clutch slip when it's actually in gear?,I no the selector bushes wear on the gear selector but u say all the gears seem to be there?
Well you will mess with these cars....
Mk4 golf gttdi highline. Mk2 golf 1.8T
mk14dr
Jan 22, 2012 11:23:51 GMT
The clutch wasn't slipping before hand but now Ive messed with the cable adjustment it might be. Looking at the receipts the clutch was new last summer, so I'm hoping its something less involved that a new clutch...
mk14dr
Jan 22, 2012 11:24:48 GMT
Yeah, all the gears are there. The box feels quite positive when the engine is off.
Jan 22, 2012 11:36:23 GMT
I'd start by checking the gear selector bushes near the bulkhead,a friend of mine had a similar problem a while back
mk14dr
Jan 22, 2012 11:42:17 GMT
I had a good look at them last night, and although they feel a little notchy everything is attached and moving freely.
Like I said, the gears are all selectable when the engine is off, but twhen its running its like I'm not pressing the clutch all the way down.
Jan 22, 2012 12:00:10 GMT
could be like my polo when I came back from the MOT, the RAC guy said my gearbox was broken, turned out that the gearbox mounting under the car came loose. I could get some gears but not others, so I thought it was the linkage that had shifted, instead the centre has come out of the gearbox mounting that was under the car its a long shot and I don't know how the grearboxes are mounted on the golf's
Jan 22, 2012 12:04:38 GMT
Can't get my head round this one?! ,knackered cable?
mk14dr
Jan 22, 2012 12:28:19 GMT
So, Ive just taken it around the block. I started it but couldn't get any gears (other than reverse and that went in with a grind and then the car crept backwards) so I started it in 1st and was able to very carefully (or with abit of force) select all the gears while driving. It still feels like the clutch isn't being pressed enough but it also slips under power aswell. So its neither fully disengaging for me to change gears nor fully engaging to stop it slipping.
Otherwise, its an awesome car.
Flippin' 'eck.
Last Edit: Jan 22, 2012 12:37:55 GMT by mk14dr
mk14dr
Jan 22, 2012 12:40:33 GMT
I'm gonna get a new cable tomorrow anyway as it got to be worth a go for 12quid, although the current one looks brand new. Ive just double checked and a new clutch kit was bought in July last year and I assume fitted by the previous owner not long after. I really do hope its not a clutch/box issue and more a cable issue.
Jan 22, 2012 12:50:48 GMT
If you know someone with a ramp it's not a huge job to get the box off but still a last resort I'd say!,might well just be the clutch by the sounds of it
Jan 22, 2012 13:57:37 GMT
A common problem is the centre of the release plate cracks & the clutch actuator arm then goes through it & it doesn't matter how much you try & adjust the clutch it will still drag & not go into gear. I've had this happen to me on a golf convertable I had & from what i've heard its not an uncommon problem with them! Tim....
Last Edit: Jan 22, 2012 13:58:08 GMT by Brat-Man
1974 Chevrolet C20 Camper Special Pickup Truck 2002 Fiat Multipla oil burner SOUTHWEST SWAPMEET southwests best car parts selling page on facebook for retro/custom/classic www.facebook.com/groups/249875865097198/
mk14dr
Jan 22, 2012 14:27:38 GMT
Cheers Tim. Is it possible to buy the plates separately? 'Box out job then? It does look like it'd be too much hassle to do, although I think I'll just take it to the garage over the road to sort and they can MOT it at the same time....
Jan 22, 2012 14:44:57 GMT
I would go with a release bearing issue or the releasing fork.
mk14dr
Jan 24, 2012 18:55:07 GMT
Righto, all sorted now.
It seems some swarf had got in between the clutch and the flywheel, and dropped out when the clutch was removed. New clutch in, bolt it back up and away we go.
Bah. Lets see if I can keep it in one piece for awhile.
