Impressive stuff - didn't know about the tie bar weak points - you certainly aren't going to pull those out
Looking forward to see what direction it all goes
Mar 10, 2012 12:07:45 GMT |
didnt know you was still going with this james, as well as the kadett. Nice one.
Mar 10, 2012 16:08:12 GMT |
Hello, the job you're doing looks great. I'm interested in how you beat the contour into this part though:  I know about metal stretching but I can't see where exactly you stretched it.
countvauxalot
@countvauxalot
Mar 12, 2012 16:59:13 GMT |
Thanks Chaps - wheeler i simply bent it by hand
monkeytennis
@monkeytennis
Mar 15, 2012 17:31:28 GMT |
Hello matey, I Pm'd you back, if you could reply that would be great, it also takes my mind off your awesome fabricating skills
countvauxalot
@countvauxalot
Mar 15, 2012 22:18:13 GMT |
PM on its way...
countvauxalot
@countvauxalot
Mar 15, 2012 22:24:18 GMT |
New engine aquired  1800 16v small block x18xe1 (so mounts the same as the original engine and uses the same gearbox, shafts hubs etc) I'm thinking R1 bike carbs
Mar 16, 2012 22:09:14 GMT |
Top work...any oppurtunity to say 'penetration' repeatedly has got to be good!
vaghag
Mar 17, 2012 18:18:50 GMT |
just read this thread, great work mate!!
no its not a Sirocco
dtvracing
On the diff....
Mar 17, 2012 21:35:39 GMT |
Car is coming along great, dotn worry about the welds on the seams, paint covers all sins. seam sealer is C%#T when trying to weld neatly. but great job so far, looking forwward to the outcome of this
I love these, they have the "hooligan" look about them straight from the factory!
countvauxalot
@countvauxalot
Mar 17, 2012 22:25:33 GMT |
Thanks guys
nofrills
my wings are made of Steeeeeeeel!!!
Mar 19, 2012 12:23:06 GMT |
Gotta say buddy this is just awsome and your fab skills are excellent.... loving the way this is coming along
countvauxalot
@countvauxalot
Mar 19, 2012 16:15:49 GMT |
Gotta say buddy this is just awsome and your fab skills are excellent.... loving the way this is coming along Thanks you sir - more updates soon ;D
countvauxalot
@countvauxalot
Mar 20, 2012 17:20:15 GMT |
Hi good people! I have for you an actual update!! this brings us up to last weekend. So here she is looking very sorry for herself not having been touched for some time - shame on me i know.  However all of my previous work looks ok still   To get the ball rolling i stripped the front struts off the hub carriers   the end result ready for some cleaning   that sorted i moved back to the car, jacking it up a bit to have a poke around  remember this!! Its the main reason i was going to go with the saloon arches as it really needs a quarter given the amount of rust and damage to the arch (the damage goes up past the area a normal repair panel would cover)  and this  having never investigated this cr@p properly i decided attack it with the grinder, now i kew the filler was thick but ffs!  once it was ground back you can see the arch has been beaten back all the way to the crease of the arch 3ugger!   The whole area was like a winter wonderland!  Looking to investigate further i decided to remove the sill - spot welds uncovered  drilled out   Then i cut a small chunk out knowing there was a support between the sill and the body in there somewere  there it is down there  Little did i know not that i was too surprised it was rotten as fook anyway!  so i chopped some more away to see how bad it was  Mmmm another hole in a stupid place to get to  some more chopping  looking sh1t - i could really do with getting in there to repair it properly, i will have to have a think as to what to do.  As it was getting dark i moved inside to get on with some turrets - some steel i bent earlier   cleaned that up  and made a lid out of 4mm  welded the top on the out side   and the inside  then cleaned it off    Thats it for now James
