longman
Club RR Member Number: 3
Fog light woes , fixed :-)longman
@longman
Club Retro Rides Member 3
Feb 10, 2012 20:34:47 GMT
evening , I'm a leccy numpty so can anyone help. I have 12v between terminals on both fogs when on , if I put bulbs in they don't light and the voltage is 0 , any ideas?
Last Edit: Feb 10, 2012 22:00:31 GMT by longman
Paul 98 500 SL 86 911 Carrera/sold 23 Octavia Phev
prey
Feb 10, 2012 21:01:28 GMT
i know this isn't answering your question but is this front or rear fogs? as front aren't mot-able afaik.
longman
@longman
Feb 10, 2012 21:05:32 GMT
rears , decided to run a separate earth to the engine , tested before hand and now only 0.6 of a volt
john61
just give in to it
Feb 10, 2012 21:35:17 GMT
;D u need a multimeter.........conect 1 probe to a good earthing point on body select continuity or ohms on multimeter connect other probe to earth on bulb holder should read 0000 on meter indicating NO earthing fault then test across contacts on bulb holder if it reads 12 v but bulb inop (ghost voltage) indicates a bad positive (live connection ) check voltage at fuse iff fitted then continuity through switch (back on ohms not voltage ) should have 0000 on meter between switch live )from fuse and live out to lights if no fault found on fuse or switch check connectors to back of car ;D
Porsche 911 SC VW T25 SYNCRO BSA C 15 HONDA CBR 1000
longman
@longman
Feb 10, 2012 21:49:37 GMT
continuity from the earth to block was 0 or as near as damn it with a little wiggling of probes and was 12v over contacts in both bulb holders , gonna play at the fuse end now , cant feel my fingers though... may find solace in beer
longman
@longman
Feb 10, 2012 21:58:59 GMT
it lives! , removed and reseated relay and rotated fuse about a bit , bright shiny fogs ;D ta fellas
Last Edit: Feb 10, 2012 21:59:42 GMT by longman
