Feb 13, 2012 12:46:46 GMT
hi everyone, i thinking of fitting a zetec enging from a focus into my avenger does anybody know how difficult it is to use the stock ford engine management system from the focus instead of using the stand alone ecu or bike carbs has any body done this? cheers matt
Feb 13, 2012 12:54:12 GMT
Focus = difficult (lots of integration between the body electrics and the ecu, and a complex immobiliser).
Also, not many Focuseseses have a Zeta engine (Mk1 2.0 IIRC) - which is what you need to bolt up to a Type 9 or MT75 for RWDness.
TBH, you'd be better off searching out an early Mk1 Mondeo (or Escort of a similar vintage). The earliest ones don't have an immobiliser, so the ecu wiring is easy - it only needs a few wires connecting to the ignition switch. The immobilised mondeos have a bit of red plastic on the front edge of the ignition key, while the non-immobilised ones don't.
Obviously, buy the engine on condition - it would be giid to be able to smoke round in the donor for a while to make sure the engine's a good'un. Don't be scared of one with a high milage: the Zetec is a tough old thing: the one I owned briefly had 135,000 on the clock, had suffered a bit of neglect, and used absolutely no oil or water. Pulled nicely, too.
dazcapri
North East
Enter your message here...
Feb 13, 2012 13:37:18 GMT
mrbushrat on here is running a zetec in his avenger dunno if his standard ecu or not but might be worth a look in his thread
Mk3 Capri LS
bortaf
Feb 13, 2012 15:04:43 GMT
R.I.P photobucket
ftz313
Feb 15, 2012 19:03:58 GMT
I've just sussed out how to remove and run a pats loom out a mondeo. Obviously you need the right key to go with ecu. You cut all the wires at the engine block connector, join 5? positives up, an earth and the 4 pats wires. Yip that easy.
rodney
Feb 16, 2012 22:53:45 GMT
Feb 19, 2012 22:06:36 GMT
