bstardchild
Club RR Member Number: 71
Jun 18, 2007 10:59:29 GMT
IntroductionSome pics I think either PhoenixC or I found and snaffled of the interweb of a car in happer days The find.......Then a conversation on another forum about a potential competition Monza that was for sale started. DownsideThe realitySome pics - recent of what it looks like now.................. It looks a right state doesn't it? I think it's going to be stripped for the bits that can be saved The vehicle details for B733 WES are: Date of Liability 01 09 1990 Date of First Registration 01 03 1985 Year of Manufacture 1985 Cylinder Capacity (cc) 2968CC CO2 Emissions Not Available Fuel Type Petrol Export Marker Not Applicable Vehicle Status Unlicensed Vehicle Colour WHITE Vehicle Type Approval null
Marc
Jun 18, 2007 11:04:44 GMT
I just don't understand the logic of people stashing things like that in barns for years and allowing them to rot.
Jun 18, 2007 11:08:34 GMT
Doesnt look that bad TBH Fire damage always looks a lot worse than it actually is when you start stripping Its a competition car, so the interior is pretty "Superficial" anyway, the seam welded shell and running gear should be ok too.... need a full rebuild with bushes and bearings etc but still well worth saving ;D
Jun 18, 2007 11:41:21 GMT
who drove the monza in the brc in the early 80s? got a ticking off from the officials for removing the rear hatch on the manx rally iirc...
*n
bstardchild
Jun 18, 2007 11:50:14 GMT
who drove the monza in the brc in the early 80s? got a ticking off from the officials for removing the rear hatch on the manx rally iirc... *n Austin McHale, Co-Driven by Christy Farrell - I think There is a suspicion that this car was previously Lanfranchi 1985 Touring car
Jun 18, 2007 11:54:50 GMT
eeeew.
Burnt interiors alway have a special look of yuk to them
Jun 18, 2007 12:01:03 GMT
The engine and body might be okay, but the cost of replacing the electrics, engine sensors, interior and everything else would huge!
superficial (possibly) easy and cheap to put right (no)
EDIT: It's a shame, hope some one with the time and energy will sort it out
Last Edit: Jun 18, 2007 12:02:13 GMT by Robinxr4i
Jun 18, 2007 12:20:52 GMT
Problem with that is that you'll never get a good paintjob on it as the burnt paint will seep out of the metal even if you sandblast it.
Matt
Jun 18, 2007 12:26:43 GMT
really?
One other thing is that there is a form of acid type thing which comes from burnt plastics, chloride based or soemthign I forget, only get it from burnt "black boxes" in 80s cars and later. If you get it on your skin it burns and you cannot do anythign about it. Saw a thing on telly years ago about a guy working on a fire damaged Acclaim (IIRC) and lost his hand with the acid burn from the black box.
Jun 18, 2007 12:30:06 GMT
It happened a few times when I used to work at the recovery garage as one of the guys had a side of fixing damaged cars and selling em on. No matter how much paint you put on you could still see where the fire damage was under the paint it was a nightmare.
Matt
Jun 18, 2007 12:34:45 GMT
Not one I've come across before. I bodged up the bonnet of a Mk3 Cortina after an underbonnet fire, it was a mess but mostly because I did a cack job of it. I've seen a Chevy which was restored after a fire and that was OK though.
Jun 18, 2007 12:34:47 GMT
That car is totalled!!!!!
Jun 18, 2007 13:05:08 GMT
I`d be sending the shell to SPL for dipping and Phospating I`m with AK, never had a problem painting over Burnt steel Oh and thats how the Tuthills strip all their Porsche shells for Classic rallying ;D Big Gas furnace and burn it all off ;D ;D then blast it to clean and key As for loom and sensors, there wont be a lot in there and it wont be anything too trick either..... Now if it was a 90`s touring car or a WRC car thats different, but that age should be pretty simple, doubt it even uses Mil-spec connectors
bstardchild
Jun 18, 2007 13:34:59 GMT
I`d be sending the shell to SPL for dipping and Phospating Well it is being stripped for spares but the reason for this post was to get some second opinions as it's been condemned on another forum - I am interested in the shell as a replacement for my Monza - mainly because it's not got a sunroof and also cos its a similar age as well as having a bit of historical interest. I actually want the bits stripped off it as once that happens the shell is going to have pretty much no value with all the best bits cherry picked - so I would hope I can snaffle it for scrap value (hopefully with a log book)
Jun 18, 2007 13:45:53 GMT
Makes sense to me ;D Was it a weld in Cage ? Or was it a Bolt in Its the right age and nationality to have had a Matter Prepared shell I would think Which may mean Alloy Cage too If thats the case then the cage will be scrap, if its steel it should be ok ;D It will be a lot of work but its also a hell of a car with some proper history, its a reall shame in one respect that its being broken but if you can bag and restore the shell then thats the investment for the future Try and keep tabs on all the parts as well......... just for reference you understand And pics of all the components as they get stripped would be useful too Think that Celica/Integrale/Quattro rebuild thread type pictures and you wont go far wrong
filmidget
East Midlands
Mostly Lurking
Jun 18, 2007 13:56:25 GMT
F-in-l has mentioned this nasty acid before - might be in burnt brake components too?
Limbs can be lost apparently? I am sure he mentioned possible fist aid in extreme cases being an axe so it didn't spread anywhere vital!?!
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
Jun 18, 2007 14:10:31 GMT
apparently if it gets into the blood stream it just eats up stuff from the inside, dunno, sounded too sci-fi to be true.
bstardchild
Jun 18, 2007 14:29:24 GMT
Makes sense to me ;D Was it a weld in Cage ? Or was it a Bolt in if its steel it should be ok ;D Welded in and steel - for some reason it has an alloy cage as a spare which I think has already been snaffled by another ABS member Its the right age and nationality to have had a Matter Prepared shell I would think I think but I'm not sure it wasn't prepapred by Matter - swindon rings a bell It will be a lot of work but its also a hell of a car with some proper history, its a reall shame in one respect that its being broken but if you can bag and restore the shell then thats the investment for the future Agreed - I thought that - either as a replacement shell for mine if I bin it on a track day or to use as the base for my next Monza engine - I don't want to update my Monza thread cos I think most people are sick of it but I now have sourced a 3.6 crank shaft and rods and a suitable block that will be opened out to 96mm bore and have the clearance enlarged in the rod area to take a stroked crank This was to be the new engine for my existing car 3.7L N/A straight six but could just as easily be used in this shell and leave what I have alone Try and keep tabs on all the parts as well......... just for reference you understand I know where nearly all of em are going And pics of all the components as they get stripped would be useful too Might not be able to do that - I can ask tho ;D Think that Celica/Integrale/Quattro rebuild thread type pictures and you wont go far wrong I had that in my mind too
Jun 18, 2007 14:30:06 GMT
Nah i'm sure it is true, i've heard that before, defo. I'm sure its certain types of synthetic rubber and/or electrical components that turn into it when fired.
How did this car catch on fire, was it vandalised?
Gearbox looks OK.
bxer
Jun 18, 2007 14:30:35 GMT
That'll be hydroflouric acid then... nasty stuff Read all about it on Wikipedia(Scoll down to the Safety section if the chemistry does yer head in ) and here's where it comes from: (from the article)
Last Edit: Jun 18, 2007 14:32:40 GMT by bxer
