MrSpeedy
East Midlands
www.vintagediesels.co.uk
Mar 20, 2012 13:45:46 GMT
Last Edit: Mar 20, 2012 13:46:38 GMT by MrSpeedy
Mar 20, 2012 14:16:17 GMT
Never tried them, TBH. As I'm sure you know, the triple electrode doesn't produce a better spark, but it does mean that they last about 3 times as long between servicing, which is why the are quite common on modern cars with long service intervals. I used to be a fan of NGK, but they don't seem as reliable of late - I've had a new one fail, as have friends - a change in the prodution, perhaps?. I've switched to Nippon Denso from spark-plugs.co.uk/index.php/search/simple/14438. I'm not sure what grade you need, but the Imp takes NGK BP6ES, and the Denso plugs that I hae in there now are W20EP-U. They cost £1.69/ea inc VAT but plus P+P. A truly high-performance option might be Denso Iridium plugs (the IW20 is the cross-reference from the W20EP-U). These have a very small tip, which improves flame front propogation. Someone in the Imp club fitted a set to his highly tuned engine and found that the idle was smoother, and the short-term mixture variation recorded by his wide-band lambda sensor was smaller, indicating a more complete, more consistent combustion. I plan to try a set at some stage - but the ~£30 entry price has put me off so far.
Last Edit: Mar 20, 2012 14:33:05 GMT by jrevillug
AccusparkChasR
@chasr
Club Retro Rides Member 170
Mar 20, 2012 22:26:15 GMT
I reckon part of the NGK issue comes down to the place of manufacture. On my Stag when I was buying new plugs for it (NGK BP5ES) I had the choice of buying one batch that were made in France (Halfords), or Japan (from the motorfactors). So far I have not had any issues with NGKs. I did many years ago, but that car did have a whole host of strange issues (one of which was a shot head gasket). The one dependable brand I have found (and fairly cheap to boot) are the Bosch plugs. If you require some at a half decent price, PM me (I may know of a cheap supplier).
